Question about Kitchen Ranges
Toro power plus E125v-N/10964B . jump started motor (no wiring loom) motor ran for about 1 min, now there is no spark at plug. Thanks in advance for any help you can give. Cheers Les
SOURCE:
SOURCE: car wont start
these cars go through coil packs regularly as the packs overheat due to their position on the end of the engine. I have 3 lanos and have replaced all coil packs at around 90,000 k's.
Hope this helps.
Posted on Nov 26, 2008
  • 4 Answers
SOURCE: 07 ktm 450sxf wont start
take your carb out, clean the entire thing, that means every nook in that *****. do this and if still a problem write back because in most cases were n idiot is involved, this is the most over looked problem
Posted on Feb 17, 2009
SOURCE: Homelite AP 125 two stroke motor will not start
If you have a two line fuel system make sure the lines didn't get crossed. If they are you could still get gas to the cylinder but not enough. I hope this will of some help to you. Donnyb60
Posted on Mar 18, 2009
  • 17 Answers
SOURCE: Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Posted on Aug 11, 2009
  • 5 Answers
SOURCE: ls9100 to er600 cashregister
I don't believe CRS provides pinouts for that scanner and cash register combonation. It would be easiest to just buy a cable from them or a local dealer.
Posted on Feb 04, 2010
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
My toro 2450 keeps bogging done after 10 min. Fuel is new and just changed spark plug. Any suggestions?
Could be stuff inside the float bowl holding the float OPEN and flooding it. That IS a weird symptom. Possible coil failure.Is there spark after it dies? Will it re-start? Was the spark plug wet with fuel?
Feb 05, 2014 | Toro Lawn Mower With Toro Power Tools
TORO POWER CLEAR 418 ZE WILL NOT START
Could be many problems, check plug, check plug gap, check plug wire an connector, check plug to see if spark is jumping gap, if so then mag is good. Check to see if shut off ground wire is killing engine, just unplug it an try to start. Fuel problems should be checked, look for cracked fuel line, clean carb, get rebuild kit, very cheap, be careful to put back properly, clean with carb cleaner, clean all ports small an large, use small brass or steel bristles from brush or what ever you have to clean small ports. Put back together it should run. Replace lines in tank as well.
Dec 04, 2013 | Toro Garden
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
I have the 6.5 hp self propelled model, It starts fine and runs strong for aprox 5 min then dies, seems to die when it gets hot possibly, the die time is always the same aprox 5 min. Once it dies it will...
I don;t know what engine is on your mower but if it has the self contained electronic ignition coil I have seen happen on several engines. It would run good for several min. then the spark just stops . And it will not spark again until it sets and cools . Just make sure it is the ignition that is not working.
Sep 15, 2010 | Toro Lawn Mower With Toro Power Tools
My toro started ran for 5 minutes and died...like it ran out gas
It sounds like it is time to replace the ignition module from what you are saying. The motor heats up and the electrical in the module open up.
I would check the spark plug as well and stay away from resistor type plugs.
HTH
Good Day.
Oct 24, 2009 | Toro Lawn Mower With Toro Power Tools
Jul 04, 2009 | Toro Lawn Mower With Toro Power Tools
Won't start,motor won't turn over.have checked battery,not battery.
i am assuming that it has gas in it and that it is attempting to start,but just not starting, so the next two things i would check would be the fuel filter and the spark plug. check the spark plug by 1) removing it from the engine, 2) reconnecting the plug wire to the plug, 3) grounding it against a metal part of the mower, 4) have a helper try to start the mower while you look for sparks coming from the plug. if it doesnt spark the plug's prob bad. if the plug is good then try replacing the fuel filter (they are cheap)
if it doesnt even attempt to start(starter isnt turning) its prob the starter solenoid.
Jun 13, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower won't start
I think if you remove the rope pulley you'll find that the shaft connector has failed; look under the mower to see if the blade moves when you pull the start rope; but, only after the spark plug wire has been removed...
(we don't want an accidental start!
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Starts runs min. or two then stops....
Go to toro.com then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Apr 05, 2009 | Toro Lawn Mower With Toro Power Tools
Kitchen Ranges Logo
142 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
