Question about GE Profile Spectra JGBP85 Gas Kitchen Range
We have a GE Spectra XL44 model gas freestanding oven. There is a strong gas smell if we try to use the oven or stove top burners. When everything is turned off the smell goes away. The oven is about 7 years old now and we are trying to decide if we should buy a new one or try fixing this model. I was wanting to know if it could be a regulator problem and if so how much those run to replace?
SOURCE:
catriver
  • 878 Answers
SOURCE: GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Posted on Dec 08, 2006
  • 41 Answers
SOURCE: GE TrueTemp Gas Stove
Not sure that I can help but will give it a go. Often the igniter plastic covering comes off the wiring from the heat of the oven and the igniter arcs on a metal surface on the oven. I had this problem with a gas oven I had. Check along the igniter wiring to see if it is arcing. Best way to find it is to firstly locate the wiring then ignite the oven WITHOUT THE GAS ON. If it is arcing you should be able to see a little flash. Check to make sure it is flashing at the right spot first near the pilot. Easiest way to rectify this problem is to wind electrical tape around the igniter providing you can get to the wire. If you have to pull out the igniter you can buy a plastic product called Heatshrink from places like Tandy or Electrical Hardware Stores. Just put some Heatshrink or Electricians Tape around it and it should solve the problem. Only other thing it could be is the igniter needs replacing. Hope this helps.
Regards
Bryan
Posted on Feb 28, 2008
  • 145 Answers
SOURCE: Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
a16646a.jpg to you.
Posted on Dec 23, 2008
aborcass
  • 2651 Answers
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Posted on Jun 08, 2009
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
I have a GE XL44 gas stove the oven will not stay lite why?
That's bad. Sounds like the burner is dirty.
and the gas belive it or not is blowing the polit out it hit it so fast. The gas can't go in the burner. There should be two screws that hold it in place take it off and clean. See if that will work. Let me know.
Ken
Sep 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 range gas smell
it's the safety valve, it's bypassing the gas. for you to put soup in there you will have to remove the oven burner. and put the soup on the tip of the orifice that's where the burner sits on.
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85 Gas Kitchen Range Logo
156 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
