I860 used ink tank full - Office Equipment & Supplies
  • 2 more comments
  • Anonymous Jul 26, 2008
    Used Ink Tank Full
  • Anonymous Oct 08, 2008
    THE USED INK TANK IS ALMOST FULL.
  • dadsbarmy Dec 19, 2008
    each time I print a warning says used ink tank nearly full
  • barbdoll29 Jan 08, 2009
    Used Ink Tank Full
The Canon website states that the "ink absorber" needs replacement. The printer will not function when the absorber is "full" They discourage self-servicing the absorber, as "replacing the ink absorber is a complicated and potentially messy procedure," and lists authorized service locations based on zip or address. One authorized shop quoted $59 labor plus parts to replace. Almost better to buy a new printer.
Posted on Jan 22, 2009
JongCur
  • 88 Answers
SOURCE: waste ink tank full
normally, the logical solution is to replace your waste ink tank, but I have tried a solution which could make your canon printer function again.
Try this: With your printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Posted on Oct 06, 2008
Bappa170873
  • 505 Answers
SOURCE: My Canon i860 is not
If everything is clean and working fine then you need to first replace the ink tank and then check.
Also check if its happenning with eery application or some specific applicaion like MS WORD or MS POWERPOINT.
Thanks
Posted on Nov 14, 2008
Gletkin
  • 49 Answers
SOURCE: Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
Posted on May 31, 2009
komguy
  • 2306 Answers
SOURCE: canon i860 used ink cartridge full error message
When the absorber is full, you need a shop to replace the absorber pads and reset the waste ink counter. In our shop the pads are $19.95 and the labor is $69.00. Sorry about the first stupid answer to your problem.
Posted on Oct 02, 2009
  • 256 Answers
SOURCE: Cannon i860 giving error saying
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
http://social.technet.microsoft.com/Forums/en-US/itprovistaprinting/thread/a1e247a6-52d2-416e-8432-ce3e361a9547/
Hope this helps you.
Posted on Jun 28, 2011
Cannon i860 giving error saying waste ink tank almost full, how can I fix it?
3: Connect power.
Jun 19, 2011 | Canon i860 InkJet Photo Printer
I have a canon i860. The waste ink tank is full. Where is it located on the printer and can I empty it myself?
No. Send it back to the company for recycling. There should be some way to exchange them for empties wherever you buy the ink.
Mar 20, 2011 | Canon Office Equipment & Supplies
Says "Used ink tank full". Light blinks and won't print. No idea how to empty.
It sounds like you refiled an empty ink tank. The printer will refuse to accept ink cartridges that have been used and refilled. Unfortunately there is only one easy option: Buy a new cartridge. If it is a new cartridge and has not been refilled (straight out of the box), contact the supplier (where you got the cartridge from).
Good Luck!
Jun 20, 2010 | Canon i860 InkJet Photo Printer
Used ink tank is full. i removed and cleaned everthing. it still comes up and says its still full???? how can i reset faults, or what needs to be done??
This will reset the error code, but the absorber is still full of ink and will overflow ruining furniture, and possibly the printer. I don't know how you got that code sequence or why you would be that careless to give it out in a public forum.
Dec 13, 2009 | Canon i860 InkJet Photo Printer
Canon i860 used ink cartridge full error message
Sep 26, 2009 | Canon i860 InkJet Photo Printer
May 11, 2009 | Canon i860 InkJet Photo Printer
Waste ink tank over flowing??
Hi, like every ink jet printer, there should be an ink pad(spunch) at the bottom of the printer to collect the waste. That spunch might be full of ink. You could locate it, remove and try to clean it under the water. See if it works
Apr 03, 2009 | Canon i860 InkJet Photo Printer
My Canon i860 is not printing magenta. I run all the maintenace functions -- nozzle check pattern, print head alignment, cleaning, and deep cleaning -- twice. Problem persists. The magenta ink tank is...
Thanks
Nov 14, 2008 | Office Equipment & Supplies
Waste ink tank full
Aug 26, 2008 | Canon i860 InkJet Photo Printer
753 people viewed this question
k24674
jasbo
jasbo
