Question about Panasonic KX-FLB756 Plain Paper Laser Fax
I received an FLM551 laser fax/scanner printer that was sitting around
I can't print and I call service 03
do ya think a new drum will fix it?
the scanner works fine but won't print
software says call service 3 also "something is wrong with your printer.
What do you thnk?
tks
Eddy
  • khurramarain Mar 24, 2009
    i have pansonic kx fp 612 its give singn of call for service 03 what the mean of this can you explain it please
I need a driver also
Posted on Oct 07, 2008
When we receive faxes, Only the very right side prints out. WE have a new ink cartridge and drum unit. It did it before we changed it and it is doing the same thing. Is there anything that we can do?
don't know if this will fix prob, but pull drum unit out and locate the piece of glass that runs right to left inside of fax right over top of where drum would be sitting. clean that off. if theres toner coating that glass, that will cause light prints or blanks. this is of course, assuming that you are getting these kind of prints from more that one fax.
hth,
razors
Jun 15, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
A drive for panasonic KX-FLM551/FLB751 ?
I checked their website http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/model.KX-FLM551
It doesn't list any Vista drivers yet. Have you tried running it in Compatibility mode for XP?
Jan 14, 2009 | Panasonic Workio DP-2330 Printer
Laser printer black streaks
clean scanner lens with glass cleaner applied to microfiber cloth aslo clean copier glass if this doesnt fix it replace toner/drum cartridge
Jan 24, 2008 | Canon imageRUNNER 1370F All-In-One Laser...
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Panasonic KX-FLB756 Plain Paper Laser Fax Logo
182 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
