Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint side by side makes a high pitched "howling" noise. Sometimes is worse then others and will sometimes stop when the door is opened.
    New Friend:
  • 51 Answers
ANY TIME YOU HAVE SIDE BY SIDE REFRIGERATOR IT ALWAYS RECOMMANDED TO HAVE LEVEL FLOOR AND YOU MOST SET UP THE BOTTOM ADJUSTEMENT SO THE REFRIDG CAN BE LEVREL AND STABLE WHILE RUNING.
Posted on Oct 24, 2010
SOURCE:
2003 ford sport trac front grinding noise from drivers side when sharp left turn
go to the magicmechanic website and send him this--hes the best there is and will rply
Jan 19, 2015 | 2003 Ford Explorer Sport Trac
Constant speed howling noise from underneath 2003 Volvo S60 (base)
Open the oil filler lid and see if the noise goes away - or lift the oil dip stick. It could be a gummed up PCV system that causes pressure in the crank case that "whistles" when the engine is running.
By opening the lid or dip stick, you're letting the pressure out and the whistling should stop.
If this is the issue, FCP Euro has a PCV replacement kit for about $350.
Jul 16, 2017 | 2003 Volvo S60
Hotpoint refrigerator sounds like a high pitched siren
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Mar 17, 2011 | Hotpoint HSS25GFP Side by Side...
Medium humming noise when backing up at low speeds
Probably rear brakes. Clean them up or get them looked at and try again.
Jul 14, 2010 | 2001 Honda Accord
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
My refrigerator/freezer making a howling sound and an intermittent whirring sound. I have noticed this at night, not sure if it is doing this during the day.
I have the same model, and the exact same problem. Additionally, the compressor/fan for the freezer cycles up and then down (rising and falling noise pitch) at a frequency of about every 5 seconds. The howling is worse at night(!?). It is 4 yrs old and was in the house we just bought. Help quickly, or this is a CraigsList item.
Thanks
Jan 12, 2010 | Hotpoint HSS25GFP Side by Side...
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Variable noise in freezer
That could be an idication that the fan motor is starting to fail. The bearings go out and it starts squeaking and vibrating as the fan blade becomes out of balance. If that fan stops working the fresh food section won't get cold air blown into it and will warm up rapidly.
Feb 23, 2007 | Hotpoint HSS25GFP Side by Side...
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Hotpoint HSS25GFP Side by Side Refrigerator Logo
135 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
