Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice maker whirlpool fridge
Quit working
    Genius:
  • 1,122 Answers
FIRST MAKE SURE IT'S ON,,THEN YOU NEED TO SEE IF YOU HAVE WATER TO THE WATER DISPENSER,IF YES CHECK THE TUBE GOING TO THE ICEMAKER,PULL TUBE OUT LOOK INSIDE TO SEE IF FROZEN LOOK TO SEE IF THE WALL WHERE TUBE GOES IN IS FROZEN,IF NO TO BOTH YOU HAVE A BAD INLET WATER VALVE,TURN WATER SUPPLY OFF,REMOVE PLASTIC TUBING FOR ICE MAKER AND DOOR WATERGOING TO WATER INLET VALVE,GET THE PART NUMBER AND GO TO YOUR LOCAL APPLIANCE PARTS STORE AND GET THE NEW PART,REPLACE TURN ON WATER AND ALL SHOULD BE GOOD,HOPE THIS HELP,THE WATER VALVE IS ON THE LOWER BACK SIDE OF FRIG.
Posted on Jun 07, 2008
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Found no manual for GD5S fridge, ice machine quit working
Generally you can get an ice maker from Best Buy that fits your Fridge. I did and it works great.
Otherwise, check your water line, power source and listen to the fridge while it's running during a cooling cycle, if it makes a lot of clicking noises you'll need to replace your ice maker.
This isn't an easy answer either, my experiences have been many with multiple makes and models!
Mar 20, 2010 | Whirlpool GD5SHAX Side by Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
