The monitor keeps saying 'over range' and halts any programme. what dose over range mean
  • 4,924 Answers
That error means you've either chosen a resolution or a refresh rate which exceeds your monitor's capabilities.
Select a lower refresh rate, and/or set back to the defaults.
Try booting into Safe Mode by tapping F8 at boot
when you are into the safe mode it will allow you to default your video card ...or ..even insert the driver and reinstall it ..Reinstalling the video driver will allow it to get to the default (optimal) values..
if you can open it in normal mode...and only on certain programs does this ..than you should first ..click right on desktop ..and after that properties..and setting s(usually the last one in the right ) ..in there check the resolution and set a lower value..
Posted on Oct 24, 2010
SOURCE:
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
How do I fix 'out of range' problem when I connect monitor to my MacBook Pro
Check to make sure that closing the panel down does not cause the laptop to go into standby or suspend mode. In other words, are you sure that the video signals are not halted by the action of closing the panel down?
Oct 14, 2014 | ViewSonic VA720 17" LCD Flat Panel Monitor
What dose it mean when dispaly says bad cord
You may want to look at the cord where it connects to the range to see if it is loose or burnt. Check the whole cord to see if there are any breaks in it anywhere. The cords are not real costly so you can replace it yourself.
May 06, 2014 | GE Electric Smooth Top Range
Washing Machine starts and then halts when runs
there is a PCB fitted inside the machine which gives comand to the electical moter and the water pump and it is programmed to give those comands on regular time intrvals as per the programe selected by you if the machine is not working according to the programme that means PCB is malfunctioning due to many reasons like moisture in the cercuit or dry solder etc try to remove moisture by blowing hot air through it if still the problem persists change the pcb your machine will run normal
Aug 14, 2012 | Fisher and Paykel Washing Machines
Monitor say out of range
Just connect the monitor to another computer and change the screen resolution to 1024 x 768 or less. This means that the computer that is connected to that monitor, can not display the mode that your monitor is in right now.
Feb 27, 2012 | Princeton Digital Computers & Internet
I have a flat screen monitor sva but it keeps saying it is out of range
This means your video card is set to a frequency that is too high for the monitor to match. Lower the switching speed via the properties window on the computer. Try 800x600 @ 60hz for starters. You can reboot into safe mode by pressing and holding F8 as you reboot. This will allow you to boot in a low resolution mode which should allow you access to these settings.
Aug 29, 2011 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
My monitor samsung 2330 keeps saying check digital signal cable and I've put the cords all in the same way I had them before and now this screen keeps popping up
If you already check your connections and still no answer from what you're doing, do these steps:
  1. check for any beep codes
  2. remove and reinsert your RAM to another memory slot, if it works you have a problem with your RAM, you'll need to buy a new RAM that is compatible with your motherboard
  3. if you here a 1 short beep, that means it already start the booting sequence of your computer but you don't see any boot screen and still the out of range error. You have a defective graphic card.
  4. Is your monitor is a LCD type? if your answer is yes that means your monitor is not compatible with your old graphic card, buy a new graphic card that is compatible with your motherboard and to your LCD monitor. Because old graphic cards or onboard vga cannot hold much more pixels than newer ones that's why you have an out of range error
Aug 01, 2011 | Samsung Computers & Internet
Its say e-5 what dose this mean?
To answer your question, we need to know who the manufacturer is and the Model Number of your BP Monitor. Thanks.
Apr 17, 2011 | Health & Beauty
I have a problem with my hp 1702 please help!!!!
this means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Aug 11, 2008 | HP L1702 17" LCD Monitor
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
