Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
Phone lock code brake - Samsung S3650 Corby / S3650 Genio Touch Cell Phone
ABS light on dash is stuck on how do I get it off on a 95 Ford Explorer Eddie Bauer edition
Unhook the negative battery cable for a couple of hours, then reconnect. If the code comes back, you may have a bad abs wheel sensor.
Feb 05, 2015 | Ford Cars & Trucks
How to brake in my sonyericson 800i phone lock.
Do you want to break in the network lock to which your Sony Ericsson W800i is locked with? I suggest you can approach Wickedunlock.com and specify the country,locked network.Based on the availability you can get the unlock code along with free unlock instructions.
Oct 08, 2014 | Cell Phones
My phone is locked by phone lock. how can i brake this.
Phone lock is the default secret code which comes with the phone. If you got the phone brand new and have not changed the phone lock code then refer to the user manual of your mobile device to get the default lock code for your unit. This varies from phone model to model. But usually an easy number either 00000 or 12345.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Aug 10, 2011 | Samsung Cell Phones
Lock code i forgot it
try using master code or brake the lock
Apr 27, 2011 | Nokia 5800 XpressMusic Smartphone
My security code can't brake it
You can unlock the mobile from the Security Lock using the Master Reset Code,You can get the Master Reset Code at
http://www.wickedunlock.com/nokia-dct-master-code-service/rs11wp10/ and Unlock the mobile.
You Check security Code for your model in the list...
Oct 29, 2010 | Cell Phones
What causes anti lock brake fuse light to stay on?
ANTI LOCK BRAKE LIGHT.MEANS ANTI LOCK BRAKES NOT WORKING.CHECK ABS FUSE AND RELAY.IF ALL IS GOOD.HAVE THE ABS BRAKE SYSTEM CODE SCAN.NOT SAFE TO KEEP DRIVING.HAVE FIX QUICK AS POSSIBLE.BECAUSE THE ABS BRAKE UNIT IS PART OF YOUR MAIN BRAKING SYSTEM.IF ABS BRAKE UNIT BAD BY BEING PART OF THE MASTERCYLINDER IT CAN CAUSE COMPLETE BRAKE FAILURE.
Oct 02, 2010 | 1996 Ford Taurus
My nokia n 73 switch on the show the error server is not support
you can flash your Phone and try,else if not solve it you must brake country lock code.
Sep 27, 2009 | Nokia N73 Cellular Phone
How can i break my phone lock code for sony ericsson w200i?
remove the sim
switch it On
press
*04*0000*0000*0000#
will work only in some models
Jul 04, 2009 | Sony Ericsson W200i Cellular Phone
ABS light
It is picking up a signal from one of the wheel sensors probably.
Go here to read files on ABS issues
http://autos.groups.yahoo.com/group/villagerquest/
  • Anti-Lock Brake Warning Indicator Always On
  • Fuse(s).
  • Circuit.
  • Hydraulic solenoid relay.
  • Hydraulic pump motor relay.
  • Brake anti-lock sensor(s).
  • Hydraulic anti-lock actuator assembly.
  • Anti-lock brake control module.
  • GO to ABS Quick Test .
QT5 PERFORM ABS TROUBLE CODE RETRIEVAL
  • Key OFF.
  • Jump Pin 4 of the data link connector to ground.
  • Key ON.
  • Observe the anti-lock brake warning indicator.
NOTE: The first code to flash will be the start code (12). Also, each code is repeated three times before proceeding to the next trouble code.
Does the anti-lock brake warning indicator flash codes? Yes No RECORD code(s). GO to the following ABS Trouble Code Identification Chart in this section and PERFORM Pinpoint Test specified for first code retrieved. If indicator is illuminated constantly, GO to Pinpoint Test D1 . If indicator is not illuminated, GO to Pinpoint Test A1 .
Jan 02, 2009 | 1993 Mercury Villager
Anti lock brake light
abs relay some times go bad
Dec 05, 2008 | 1999 Oldsmobile Alero
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
222 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
