Question about HP PL4260N 42 in. Plasma HDTV
My television is changing channels automatically, and I cannot stop it. How do I troubleshoot this issue?
  • 998 Answers
Try to check the switch of your tv if their is a close contact switch if their is one try to pull it slightly to loose the close contact.
Posted on Oct 24, 2010
SOURCE:
How do I stop my channel changing.
hi i'd put your sky box to av1 and dvd player to either av2 or hdmi 1 hope it helps
regards
shaun
May 04, 2014 | Hitachi 32LD8700 32 in. LCD Television
Sound is choppy and stops...have to change the channel and go back to old channel for sound to start again?
I have this same issue --- it kinda sounds "digital" or choppy.. then after a few minutes sound will go away all together. If i change the channel the sound returns as normal.
Were you able to fix it?
Jan 24, 2011 | Vizio VW37L 37 in. LCD HDTV
Channel changes automatically. None of the buttons seem to be stuck. Please help.
To troubleshoot this first ake the batteries out of the remote. If the changing of channels stops then the fault is with the remote not the television. Replace new batteries into the remote and see if the issue is resolved. If it continues go around each button pressing and releasing it - if the problem persists you will need to purchase a new remote.
If the problem continues even with the batteries out of the remote then you have a faulty tuner on the TV and this will need to be replaced.
Thanks for using FixYa.
Jan 19, 2011 | Televison & Video
The buttons on top of mt tv go crazy the flip channels automatically and turn volume up and down automatically
I have had this problem on this same model (F32650) and I discovered that what is happening is that dust and debris are causing the microswitches in the panel to short, therefore the channel starts changing and wont stop or the volume changes etc...
Get some electronic switch cleaner and (with the power off of course!) spray into the crevaces around each button and press each button a few times and then power the unit back on and it should be fine.
May 08, 2009 | RCA F32650 32" TV
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
Nov 07, 2008 | Sharp LC13B6US 13 in. EDTV-Ready LCD...
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
ILO sound quality
Had a similar issue and turns out I had accidentally switched my language pref to SAP rather than English. As soon as I changed it back, everything was fine...
Aug 10, 2008 | iLO 3200 32 in. LCD Television
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Hdmi issue
This may sound silly, but are you changing the channel to the HDMI channel (one of the AV channels)
Oct 12, 2007 | Philips 42PFL5332D 42 in. LCD Television
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
HP PL4260N 42 in. Plasma HDTV Logo
102 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
