Question about Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2"
Looking for a diagram or schematic for a senco fp18
    New Friend:
I have a SENCO FinishPro18 that I inherited from my son when he died a year ago. It has worked fine till now. It does not shoot a nail when depressed against a board and I pull the trigger. I don't hear air leaking, but it seems there is little pressure. Having taken apart the head, then the base, it all seems in good shape. I have not taken apart the trigger assembly, as the removal is a total commitment. Thoughts? I could use some help.
Posted on Oct 26, 2010
SOURCE:
Air leakage from bottom & no return
The internal workings of a pneumatic nailer are fairly simple and easy to diagnose problems. If you go to Senco's website at www.senco.com, you can find a breakdown of what parts are where inside your nailer. Remove the four bolts holding the cap on and check the condition of the o-rings inside the gun. They are the most likely failure point for your tool. Senco does make repair kits that contain all the wear items in your nailgun. It will be listed on the parts breakdown and can be bought at most online parts stores or places like eBay and Amazon.
Dec 26, 2012 | Senco FP18 FinishPro 18 - Gauge Brad...
Have you got diagram of scn 60
go to senco.com and you can download a schematic for the tool and also order parts from their site.
Sep 10, 2011 | Senco SCN60 Rugged Duty Coil Sequential...
I was trimming a house yesterday and my finish pro 18 quit working. The driver would not return. I could manually push it back to the starting position and then it would fire once, then stay in the...
If you diodn't replace the driver look at it. there might be a burr on it or also one where it slides in and out. Sometimes if it jams a nail or a piece came off of one it will lodge there and cause problems. This has happened to me in the past.
Feb 03, 2011 | Senco FP18 FinishPro 18 - Gauge Brad...
Missing every second nail
2 possibilities
1 trigger valve needs replacement, piston not fully retracting every time
2 feeder spring needs replacement, less likely but possible
Sep 06, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart put it together. Shoots a couple of nails then stops. Press the nailer against the target pull the trigger and air comes out of the handle.
I just had the same problem with mine. Exact same symptoms. My guess is that your gun hasn't been used in a while.
I called Senco and they recommended removing the top cap, removing all o-rings (one at a time) gently stretch them, put a small amount of lithium grease in the o-ring track, and replace the o-rings. This fixed my problem and I hope it fixes yours!
Senco has awesome tech support for their tools. I will not buy another brand because of their support. 800-543-4506
May 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
My Senco PC1010 Air Compressor just quit and won't power on, any idea what could be wrong?
on a compressor by the motor or on the pressure switch there will be a overload switch which may have tripped out push this back in and try it it is a black button pocking out the motor or switch buddy get back to me if this doesnt work budd
Sep 12, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
My senco finishpro 18 won't shoot
the seal on the piston requires replacement all seals are o rings and can be supplied by your local bearing stockists also check that the blade is straight and has no burrs
Nov 26, 2008 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2" Logo
295 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
Trippy Tripp
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
