Question about Kenwood VR-6050 Receiver
I have a KR-V6050...my remote went out so I use the Dolby ProLogic button on the set itself...one day neither of the Dolby option buttons would work..after about a month, I turned it on the the Dolby worked...I left it in that position. Later on I turned on the receiver and it is off and the buttons will not work again..do u have any idea?
SOURCE:
Mark_Webber
  • 472 Answers
SOURCE: Sony STR-DE697 7.1 - Needs Dolby Prologic IIx
I can think of 2 way this can go.
  1. Sell your current unit and put the money from that towards the upgraded unit.
  2. Sell your current unit to help pay the medical bills if you ignore the original advice.
Posted on Apr 18, 2008
jerryg50
  • 1691 Answers
SOURCE: Kenwood kr-v9020
You should find out who does the service for your reciever in your area. This type of fault can get fairly involved. It will require trouble shooting and then ordering the necessary parts.
The fault can be the motor, or the electroncs in the servo drive amplifier for the motor.
Jerry G.
Posted on Jun 10, 2008
rehortonjr
  • 47 Answers
SOURCE: receiver will not work by remote
Hi!
Here are suggested solutions for you!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:
"First try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com."
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Posted on Oct 09, 2008
  • 10 Answers
SOURCE: receiver cuts in and out
Sounds like a cold solder to me or maybe an oxidized terminal but could be something more simple.
1- If the unit still has power but no sound - Try and reseat the jumpers on the back of the unit - top middle (adapter unit)
2- If you are tapping near the speaker button it may have dirty terminals and may be cleaned with some electronics cleaner. One way to diagnose this is switch it off and on several times and see if it changes.
3- If tapping on the front panel makes it start working - can you duplicate it going back out by tapping? This may be a cold solder on the ops panel. If you have some soldering skills this may be an easy find and fix. If not you may need to take it to a repair center. By no means operate on the unit with power to it with the cover off!
Posted on Mar 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Posted on Jun 01, 2009
KR-V6050 I cannot get audio to work on radio, video or any other setting. Also the red standby light stays on all the time, even when the power switch is turned off. Alan
Check the input / output connections are in the correct places. The red standby will stay on when the unit is off showing that it is ready for use. To confirm, turn the power off at the wall. The red light should go out after a few seconds.
Nov 20, 2016 | Kenwood Kr-v6050 Audio Video Stereo...
Hi i got a kenwood audio video stereo reciver KR- V6050 how do i fix it .when i turn it on it says protect and i dnt have a remote for it
Hi
the remote has nothing to do with this.
Its in protection mode ..
check your speakers cables first
if is all OK
then the receiver needs to be serviced the power supply section has a damaged parts or re-soldering the points again , but mostly damaged parts due to age of the device or over heated.
hope this helps
Kind regards
M.Mathis
Mar 13, 2016 | Kenwood Audio Players & Recorders
How do i fix my remote to work my home theater. i have a htp-071 and my remote stopped working. the battries are brand new. I went away for the weekend and came home, remote didnt work. please help.
Test remote for operation. Problem is with either the remote or the receiver in the home theater.
Clean all battery contacts and install new, tested, working batteries in remote. Turn on am radio and tune AM dial to about 600 - turn up volume. Then bring remote to about one inch from radio and hit button on remote. You should hear a beep as long as you hold the button down. Every button will respond likewise. If nada at all remote is trashed, if works with some buttons then you have a partially operating remote. Try cleaning contacts for buttons that do not work or use some aluminum foil under those non working contacts.
Nov 22, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
Hook up everything right,but can't seem to get suround sound from TV. Went to Bestbuy and brought a Digetal Optical cable and it still dosen't seem to give mr that sound like the home theater sound---help!
On the remote press the surround mode button and set it to Prologic movies or music when you are watching TV to get the rear speakers to work.
Or if you have Digital cable TV with Dolby Digital 5.1 content, make sure you have connected theLG to your TV using HDMI v1.3a. There is an audio return channel on this cable which will stream 5.1 audio signal to the LG system.
Mar 11, 2011 | LG LHB975 Theater System
Cannot get denon receiver to go into dolby digital
pres the prologic button more that ojne time
Dec 11, 2009 | Denon AVR-1708 Receiver
I have a Yamaha HDR 6030 system and have hooked it up to a bluray player on a HD 1080p tv. Which of the sound setting (prologic, dts, dolby etc) is the best one to use for watching movies?
Each of the modes are true surround sound. Some are newer and may have advantages/disadvantages depending on personal preference. Prologic is the oldest of the listed, followed by dolby and dts. You can perform a google search to see the differences in dolby and dts but they should both be equally good. I prefer dts.
Dec 23, 2008 | Yamaha HTR-6130 Receiver
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Help for AVR - 688
check the following1-no headphone jack is inserted.
2-check power cord firmly connected.3-if you have any doubt in remote change the battery with fresh new one4-unplug the system from power and replug it.5-check your volume level maybe it is in low level.-setup your speaker again.6-check speaker cables disconnection-7 -check that mute button not pressed.
Jul 12, 2008 | Denon Audio Players & Recorders
Kenwood VR-6050 Receiver Logo
150 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
