Question about RCA Televison & Video
How do you hook up an antenna to a tv? - RCA Televison & Video
  • 998 Answers
Optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. The exact type and positioning of the aerial will depend upon your particular area. Your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable be sure to turn off all main power switches. in the media recorder you will see an aerial connector one is the input and the other one is the output. your input is the antena and the output goes directly to your tv aerial input.
Posted on Oct 24, 2010
SOURCE:
Installing an inside antenna
You can leave the input from the Roku hooked up, hook the antenna to the round connector that says antenna or cable on the tv then select cable or antenna as the input on the TV and select auto scan and let it scan for live chanels and store them...you can switch back and forth between the HDMI input for the Roku and the cable/antenna using the input button on the TV, you won't need to unhook or re hook anything to go from one source to the other.
Mar 16, 2018 | Roku Televison & Video
How do I hook up an air antenna to my tv
There looks to be a special type of connector. You might need to go to a television retailer and get an adapter.
http://www.wikihow.com/Hook-Up-a-TV-Antenna
How to Hook Up TV Antenna
Feb 11, 2016 | Televison & Video
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
Nov 05, 2010 | LG 47LG70 42 in. LCD TV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Can I hook my n64 straight to a tv antenna? The
Not directly - but you can us an RF Modulator.
CLICK HERE TO SEE.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 20, 2009 | Nintendo Video Game Consoles & Games
Hookup
Out to tv connects to your input or where the antenna for the tv is located. If you have an antenna hooked to you tv, remove it and hook in the vcr. Then put the antenna to input on the vcr.
Jan 21, 2009 | Zenith VRB410 VHS VCR
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
