Question about LG Microwave Ovens
Hi, I have a LG fully auto Fuzzy logic 4.2 kg ( model WF-421 SPC )washing machine.Its program works all the fuctions other than spinning.During the period of time of spining a littile sound is comming from the machine . but it is not rotating. what would be the reason and how do i repair this. tx/regards sanjaya.
3 Suggested Answers
SOURCE:
catriver
  • 878 Answers
SOURCE: My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Waleed, Since the microwave is going through all its motions we can feel safe that the oven and magnetron thermostats are ok. If they were bad you would not have a display. Just inside the control panel to the left, you have 3 switches which the door activates. A primary (top switch) a secondary (bottom switch) and a monitor switch (middle). If the primary or secondary switch is not closing when the door is shut, you high voltage side will not activate, therefore no heat. If the monitor switch failed or found either the primary or secondary switch closed with the door open, it would blow the main fuse and the oven would be dead. Therefore Im leaning on either the primary or secondary switch not operating correctly. When checking these switches, unplug and discharge the capacitor. This is high voltage. Good luck
Posted on Jun 17, 2006
caroldon
  • 17130 Answers
SOURCE: LG microwave oven Model MH-1296MZ
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Posted on Sep 05, 2011
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
Our beko dwd540w doesnt wash properly every wash the plates and cups ect have bits on them
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe the pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 28, 2011 | Whirlpool Microwave Ovens
What does PF mean on my LG washing machine?
According to lg PF code signifies that your washing machine has experienced a power failure,
Mar 17, 2011 | LG Microwave Ovens
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
How to convert from kg to lbs on the defrost cycle
.45 kg = 1 lb
2.22 lbs = 1kg
So if you know kg and need lbs. multiply the number of kg by 2.22. for example if you have 4 kg
4 x 2.22 = 8 lbs
May 10, 2010 | Panasonic NN-H275 Microwave Oven
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
My micorwave
Hi and welcome to FixYa,
Your described problem indicates that the logic circuitry in the main controller board is faulty. Since the logic circuitry is integral to the board, it would require an assembly replacement. On most brands/models, the main controller board is directly behind the display panel. In some instances, it could be a stuck key/button hence the logic would not reset.
Good luck and thank you for using FixYa.
Feb 13, 2009 | Samsung Microwave Ovens
Microwave comes on by itself in middle of night
We have the same problem - auto turn-on, non-functioning keys...
I called Magic Chef and they gave me another number to call:
1-888-775-0202
I called, told the rep about our possessed microwave, and they said someone will be calling to schedule a repair visit. We bought the microwave around May '08 and it is still under warranty.
Call this number and get it fixed. It is a safety problem and Magic Chef should take care of it for you.
Brian
Jul 05, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
197 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
