Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Would 1988 and up points work for a 1950 something engine? and i have no spark no matter what would that maybe just be the points?
    New Friend:
  • 41 Answers
Check your flywheel gat to mag I use a machbook (paper) should be fimne as far as the points they should work fine mmine has on the older engens of corse check your gap and kill switches
good luck
Posted on Oct 24, 2010
6ya staff
SOURCE:
1988 trooper starts runs fine till warms up shut off starts back acts like its not get gas
which engine?
we can NOT GUESS engines, ever.
get a tuneup this decade?
that be first. (spark part filters if engine is gas engine)
1988, very few of those on the road
we have one parked in a field here.
carb dead, no parts to fix it. no willing persons to fix it.
1988 had (usa) a 2.2L Diesel
and a gas 2.6L I4
the 2.6L needs a new cam belt at 60k miles
ignoring that?
and all those old spark parts, and filters.
most cars this old are zero service.
and fail to run.
new cap /rotor,wireset, spark plugs,filters and and cam belt.
and it might run,. now.
do the book published 60k service points, if ignored.
there are 50 other causes of stalling besides
neglect.
Mar 07, 2017 | 1988 Isuzu Trooper 2 Door
Where is number one spark plug wire on dist for 1950 gmc 216 ci
Since distributor may have been moved, best is to turn engine with #1 plug out until you get to TDC compression stroke on #1, then remove dist cap to see where rotor is pointing.
Feb 13, 2015 | GMC Cars & Trucks
My 1992 4.3l volvo boat engine has spark and fuel but wont run
I had this issue on my 1988 Sea Ray 4L. Spark may be too weak if your boat has old school points and condenser - gently clean the points contact surface with fine emory sandpaper - see if this works. Otherwise back to basics- Have you checked spark timing? Compression? If those are good would suspect fuel flow ain't what it seems. Good Luck!
Sep 30, 2014 | Boating
'88 mazda 323 cranks but wont start
check the distributor maybe it's out of timing or the engine has probably low compression.
Mar 26, 2014 | 1988 Mazda 323 Hatchback
My 16 year old son replaced a 1980s Yamaha motorcycle 175 but it will not start. Thinks maybe something is grounding out? What do you think?
Hi, is this a points ignition or cdi, does he have a spark at the plug? An engine needs three things to run, spark,fuel, and compression, was the engine from the same year and model, maybe the engine has cdi, and the bike is fitted with a points ignition setup?
Feb 18, 2011 | Yamaha Road Star Motorcycles
We have a 1988 Dodge Dakota with the 3.9 V6. The engine cranks and turns over very strong but will not start. I don't have spark or fuel. I have made sure the battery is fully charged. I changed the cap,...
are you getting a spark at the points, remove the cap and look at the points for a spark there.
check that the rotor arm is turning it maybe your cam or belt that drives your rotor arm and pump has broke sounds suspect that there is not fuel also. check the fuel pump and see if it is pumping they are usually run off the same cam and timing. this maybe the problem.
i hope this was useful.
Dec 12, 2010 | 1991 Dodge Dakota
88 ISUZU LEAKS GAS FROM SOMEWERE UNDER ENGINE
YOU HAVE LEAKING FUEL LINE TO THE THROTTLE BODY INJECTOR UNIT.OR YOU HAVE A DIRTY INJECTOR FLOODING THE ENGINE.
Jan 12, 2010 | 1988 Isuzu Pickup 2WD
No spark or fuel to 1988 Frod ranger 2.0 liter engine
check the ecm fuse and also for power to the ignition and fuel relays.Don't forget about the bump switch which shuts of the fuel etc when the truck has hit something or recieved an impact.
Jun 27, 2009 | 1988 Ford Ranger
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
71 people viewed this question
Top Briggs & Stratton Hammering Experts
cavs1
rlev_7
Level 1 Expert
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
