Question about Lock Technology (LT 940) Gas Tank Fuel Pump Removal Tool 940
Replacing fuel pump in a saab 9000 - Lock Technology (LT 940) Gas Tank Fuel Pump Removal Tool 940
Saab 9000 will turn over but wont start
There are a LOT of things that can cause an engine to not start. The fuel pump is only one of many in a long list. Also, hearing the pump motor running does not mean it is delivering the correct amount of fuel pressure to make the engine run.
Proper diagnostic testing needs to be done to determine which SYSTEM is causing the problem (Ignition? Fuel? Engine mechanical problems/ low compression?)
Apr 23, 2012 | 1994 Saab 9000
My 1995 saab 9000 is not getting power to the fuel pump the car has a new fuel pump fuel preasure regulator and filter now the pump won't kick in what coulld be wrong
You have a fuel pump relay,in the main fuse box under the dash,left hand it is listed as I right hand it is listed as F, check for power at the relay.
Apr 02, 2012 | 1995 Saab 9000
Saab 9000 auto wont start after freezing weather just turns over
CHECK IF YOU GOT FUEL, IT CAN BE THE PUMP IN THE GASTANK WHO GOT CRACKED IF ANY WATER IN THE FUEL (ICE )
Dec 05, 2010 | 1997 Saab 9000
No fuel on fuel rail at engine,already replaced fue pump,and relay
Some cars, like ford and Jaguar have an inertial fuel pump cut off. I don't think Saab has one, but relies on the alternator instead. The fuel pump relay is only energized for a few seconds, unless the alternator has output. So a bad alternator will cut out the fuel pump relay. This is the way all Bosch fuel injected cars work.
Jun 01, 2010 | 1995 Saab 9000
Car cranks but does not start
Fuel relay or fuel pump!!!
Sep 25, 2009 | 1992 Saab 9000
Saab 9000 lost power
The commmon thing is GROUND.
Probably the ground strap from the engine to the chassis is worn, broken, loose, corroded, or otherwise not making good ground.
Check the negative cable on the battery to see if the "pigtail" is disconnected.
Replace or install a ground strap from the engine to the chassis.
Do that first; otherwise, on the positive side, the inline 100Amp FuseLink may be blown.
Hope this helps!
Sep 17, 2009 | 1990 Saab 9000
No power from fuse to fuel pump
check in trunk for a fuel cut out switch, it shuts down fuel flow in case of an accident
Feb 15, 2009 | 1996 Saab 9000
1996 9000 CS will not start
try adding some HEET to it it is a gas line antifreeze product which also takes care of water in the gas other then that you may need a fuel pump which will require a towe
Oct 24, 2008 | 1996 Saab 9000
Opening the gas pump door (Saab 9000- 1996)
is there a rip cord in the trunk usually has a little handle on it for this exact purpose. may be hidden
Sep 20, 2008 | 1991 Saab 9000
Fuel pump crisis
If your getting power to the top of the pump at the harness and its not running, pull the pump back out and check the two power leads to the pump insert are connected. Jump power directly to the pump insert. If no go, looks like you got a defective pump.
Justin
Strictly Saab
Melbourne, FL
Sep 16, 2008 | 1991 Saab 9000
Lock Technology (LT 940) Gas Tank Fuel Pump Removal Tool 940 Logo
Top Lock Technology Plumbing Experts
Donni Steen
Tom Chichester
Are you a Lock Technology Plumbing Expert? Answer questions, earn points and help others
