Question about Canon PC-940 Black and White Copier
PAPER JAM LIGHT ON DO NOT COPY
THE MACHINE TURN ON THE LIGHT OF PAPER JAM
AND IT DOES NOT TURN OFF AND THE MACHINE DOES NOT COPY AT ALL
  • danielov Jun 07, 2008
    please help me out!
  • tedwoltz Sep 29, 2008
    My Paper jam light won't go off. I dont know where the sensors are.
    Problem Solver:
  • 9 Answers
Make sure that there is no sensor out of place or there maybe a small piece of paper blocking one of them.
open the machine and check along the paper path
Posted on Jun 14, 2008
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    Tip
    How to Fix a Paper Jam in a Copy Machine
    It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
    1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
    2. Step 2 Turn off the copy machine before pulling out the paper.
    3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
    4. Step 4 Check for any paper fragments and clean up any torn pieces.
    5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
    6. Step 6 Replace the cover and paper tray and turn the machine back on.
    7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
    on Jul 14, 2010 | Office Equipment & Supplies
    I cannot print or copy . i see error 51
    Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
    Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
    Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
    Paper jam in printer. Error light blinking.Can't get paper out
    Turn the printer off, Open the front cover where the drum and toner are installed. Remove the drum and toner (cartridge). look inside the machine for a paper jam, also open the back cover and check there.
    Apr 23, 2010 | Brother HL-2170W Laser Printer
    Savin 4035Esp - Functional Problem Message with Code SC863
    Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
    May 15, 2009 | Ricoh Office Equipment & Supplies
    Paper Jam error - red light flashing, but no paper jam!
    There may be some tiny shard of paper stuck in some inaccessible part of your printer. Examination with a bright light source may help you find it.
    Sep 17, 2017 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
    Paper Jam
    try these steps
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
    Paper Jam light on, but no paper jam
    A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
    so check theme.
    Jan 18, 2009 | Sharp AL 1631 Copier
    Xerox XC820 Copy Machine
    three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
    Dec 25, 2008 | Xerox XDL-33D Black and White Copier
    Zerox WorkCentre XD125f E2 red paper jam light
    This machine problem can be very involved.
    A paper jam as described can be in any locations of the copier.
    First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
    Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
    A bent paper tray can cause the copy to skew, causing jams.
    Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
    A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
    The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
    The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
    There is so much in this area to locate and isolate for paper feed problems.
    If all else fails, call Xerox for a service repair.
    Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
    Canon PC-940 Black and White Copier Logo
    141 people viewed this question
    old marine
    old marine
