Question about Acer Computers & Internet
Noise under the the leftside of the keyboard a little rattle or a humming noise.
    Problem Solver:
  • 29 Answers
I think the connection is loose for the keyboad or ur keyboard problem...check it out
Posted on Jun 08, 2008
Why rattling noise comes under hood and/or under chassis?
Does it sound like a valve or piston, or something loose on the exhaust pipe ?
Sep 08, 2015 | 2001 Toyota Corolla
Peavey XR 122D powered mixer developing hum noise dispite pressing the noise filter. anything more to be worth doing?
I need a bit more information but from what i can tell it's about the power supply capacitors issue, as this devices are known to develop such kind of humming annoying noise when they go under the specified value, let me know further,
Jul 20, 2014 | Peavey XR 1220 Powered Mixer Mixer Powered
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Jul 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Rattling noise from the dashbody
The noise could be due to worn universal joint on drive shaft. Could be going bad. Slowly starts as a rattle with a little vibration and over time it gets worse. If there's no propeller type drive shaft, running down the center under the car, then it is something else
Nov 28, 2013 | Cars & Trucks
I have a saturn sl2 series 2000 I just had the front wheel bearing replaced but it still make the same humming noise that it did before the wheel bearing were replaced. could it be the wheel bearings went...
Maybe the wrong one was replaced,these are tricky sometimes it sounds like the rightside but is really the leftside or the bearing was installed wrong or the bearing is not the noise, the best way is to get it on a lift and run it in drive and try to pinpoint the noise.
Jun 14, 2010 | 1992 Saturn SL2
My 07 scion tc air conditioner hums/rattles how can I fix it
If you pull out the glove box you will find the in cabin air filter, you probly want to replace it
Jan 25, 2010 | 2007 Scion tC Coupe
Noise ... raddle
When the engine is cold, go under the car and try to shake the exhaust system at the approximate spot you hear the rattle coming from. It is most likely a heat shield for the exhaust, or a broken (rusted through) hanger for the exhaust making the noise you describe. You can probably correct it with a wire or couple of screws to secure the shield, or replace a hanger.
Apr 05, 2009 | 1998 Jeep Grand Cherokee
Comppresor stoped working
Go to the back of the machine and take the lower rear plate off. Taking this plate off will expose the compressor. Check to see the compressor is humming or is hot. If niether take off the relay (located on the side of the compressor) Shake it and if a loud rattling noise is heard replace it. If no rattling noise or the compressor is hot or humming then the compressor is bad.
Jan 15, 2009 | GE Profile PFS22 33" Artica French Door...
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Computers & Internet Logo
227 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
