Question about Cisco Computers & Internet
Your call cannot be completed as dialed - Cisco Computers & Internet
Where is the + symbol on the dial face. Have tried to dial without the + symbol and the call does not connect
There is no plus symbol. Either you are not dialing the number correctly and completely, or you don't have international calling available with your phone carrier.
Oct 12, 2015 | Uniden Cordless Phone
Can I get a manual for Kunft 410/01?
You should have a troubleshooting section in your operating manual that will help you know why it may not be running. All machines are programmed NOT to operate if doors are not closed completely. You may not have the selector completely dialed onto a wash cycle, sometimes I dial mine into the off section just before the actual wash cycle begins. Could be your breaker has tripped that feeds the current to your washer. Go to your breaker box and see if the washer has a breaker all of its own and flip it back and forth to be sure it is on the ON position! Sometimes different areas of the washer dials do quit working and must be repaired. Try more than one area on the dial...permanent press, casual, normal.
Jul 07, 2014 | Sewing Machines
Why and what to do samsung s738 froze on emergency dial
have you set the emergency dial? that needs to be completed before it works, so basically you are dialing blank
Jun 15, 2014 | Lands Phones
How to remove dial up connection notification on computer screen
Go to control pannel in ur computer and then go to phone and modem then u have to select modem and then there appear all the list of connection that u have connected to the internet from there u can completely remove ur dial up connection
Oct 31, 2012 | YouTube Computers & Internet
Upper tension dial on White sewing machine turns complete circles
try a top tension of 4 or if you have a automatic setting try that
if that doesn't help then the tension dial need to be checked
to see if some thing is wrong with it, it might need to be replaced
Sep 09, 2012 | White Sewing Sewing Machines
Cannot dial a number..
you might need to eneter area code along with the number.
Jun 02, 2009 | HTC G1 Smartphone
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Problem with speed dial buttons
to program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
Feb 23, 2009 | NorStar M7324 Telephone
USB modem HiRo model H50113 will not complete phone connection
Yes you're right! What you have to do is:
  1. Right click My Network Places
  2. Select Properties
  3. Select the Advanced menu
  4. Uncheck "Operated-Assisted Dialing"
Jan 30, 2008 | Hiro V.92 56K AGERE Chipset PCI Fax Voice...
Open Questions:
Computers & Internet Logo
71 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
