Question about Refrigerators
I do not find location of bulb - Refrigerators
    New Friend:
  • 51 Answers
IT COULD BE ON BACK WALL, LELF OR RIGHT SIDE WALL THEY USUALLY PROTECTED BY A PLASTIC COVER.
Posted on Oct 24, 2010
6ya staff
SOURCE:
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
My front turn signal bulbs on my 2007 Toyota Tacoma have two elements in them, but only one is being used. Aren't these bulbs supposed to be parking lamps also?
That depending on location of bulb. Yes they r also used for parking and other things. Maybe the location of bulb iss turn signal only
Sep 29, 2015 | 2007 Toyota Tacoma
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How hard is it to change a fog light bulb on a 2005 Subaru Forester? Can anyone do it?
Front Fog Light Assembly
REMOVAL
  1. Disconnect the ground cable from battery.
105919447
  1. Remove the two clips and lower mudguard on side that bulb is being changed.
  2. Disconnect the harness connector from bulb on back of fog lamp.
105919448
Front Fog Light Bulb
REMOVAL
1. Locate back cover on fog lamp assembly where bulb is located inside.
105919462
  1. Remove the back cover.
105919463
  1. Remove the spring retainer, and then detach the fog light bulb.
  2. DO NOT TOUCH HALOGEN BULB!! Oils from skin will cause bulb to explode during operation.
Jul 27, 2011 | Subaru Forester Cars & Trucks
How do wechange the center brake light bulb on IS 300 2001
The bulb is more than likely located behind the bumper or trunk depending on where the light is located. The bulb untwists from the harness. Once the bulb is released from the harness, replace the bulb and tightened it back into the harness.
Apr 17, 2011 | 2002 Lexus IS 300
How to change microwave bulb
PLEASE UNPLUG YOUR MICROWAVE!
Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
Locate a small access cavity on the left.
Remove the screw that is located near the front of the microwave door.
Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
The bulb connection should come right out.
After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
Hope this help in solving the problem, take care.....
Sep 16, 2010 | Microwave Ovens
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
How to R&R a front Turn signal bulb from a 2007 Hyundai Entourage
look at position of bulb inside lamp assy then open bonnet feel behind h/lamp at location of indicator bulb you will locat the bulb wire socket turn this socket anti clockwise slightly it will release the socket complete with bulb pull it out then fit new bulb make sure bulb is correct one! ie the locating bayonet pins are same ? then refit socket with new bulb in reverse sequence test working
Nov 08, 2009 | 2007 Hyundai Entourage Limited Minivan
Signal bulb replacement
you may be able to access the bulb housing under the hood. open the hood and look behind the turn signal for the bulb housing. once located, grasp the housing and turn counterclockwise about a quarter and then pull. be sure to replace wtih the same type/part number bulb.
Sep 25, 2008 | 1996 Mercury Grand Marquis
Amana AM6177 Microwave
Interior light bulb is located behind the grill, above door. It requires removing 3 or 4 screws to remove grill. I have same problem. I pulled out bulb, it looks like it was glued in some type of foam material. There are two pin connectors at the mounting. but I can't see how they fit into bulb.
Apr 07, 2008 | Amana AMV6177 Convection/Microwave Oven
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
