Question about Panasonic PT-50LC13 50" Rear Projection HDTV
I have a universal remote for my Panasonic PT-50LC13 and I need to reset the lamp hours. Can anyone help?
    New Friend:
I too had a problem resetting my lamp time of my PT-50Lc13. My remote that came with the set lacked a PIP and SPLIT keys, BUT....my charter remote (that was obviously configured for my set via codes) has a PIP ability that we discovered some time ago. Instead of using the STANDARD remote, you can use a UNIVERSAL that has a PIP capability....has to be set up to work with your set first....you can hold down the VOL - key and the UNIVERSAL remotes PIP key for about 5 seconds and then you will receive a message stating that the lamp time was reset to 0.
I know this helps someone out there, and your welcome!
Posted on Nov 13, 2010
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Posted on Jul 25, 2009
Where is the lamp reset button on my panasonic PT-50LC13
To reset the lamp on the Tv you need to Hold down vol - on tv and hit either PIP or SPLIT on remote Good Luck
Nov 12, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do you reset a "lamp hour meter" on a panasonic pt-50lc13-k? Lamp was replaced but this keeps coming on screen. appreciate any help! THX
here is the link that shows you how to replace it hope this was helpful
http://www.fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Sep 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
HOW TO RESET THE HOUR LAMP WARNING
Good Day,
Reset the lamp time by pressing and holding these buttons for 5 seconds: VOL DWN (TV panel) and ACTION (remote). As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
I hope this helps.
Good Luck, Big Irish.
Dec 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have replaced the lamp on my Panasonic PT-50LC13 but now it says I need to reset the lamp timer. How do I do this?
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds in
power on condition.
Sep 28, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
On my pt 52lcx35 it says the lamp hour meter needs to be reset.
press the down volume on the tv at the same time press the up dvd/vcr split button on the remote. do this for at least 5 seconds and it should reset
Apr 02, 2009 | Panasonic PT-52LCX66 Projection Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
284 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
