Question about Sony Playstation 3 (PS3) Console
Ps3 hardisk corrupted - Sony Playstation 3 (PS3) Console
    New Friend:
  • 65 Answers
There are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot
Click Here
Posted on Oct 29, 2010
SOURCE:
Hi there, I want to know, my PS3 slim is updated with v3.60 but my hardisk is corrupted, so yesterday I have try put my friend hardisk (v3.55 installed with multiman) on my PS3, but no display when ON....
Follow the below procedures if the hard disk of your PS3 is defective;
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
I hope this helps...
Regards.
May 04, 2011 | Sony Playstation 3 (PS3) Console
I tried connecting my iomega prestige hardisk to my ps3(I just bought) but it is showing no icon or any notification of my hardisk being connected.What should I do to view its contents on ps3? about my...
You need to format your drive as FAT32.
If you are using Windows Vista or 7, you will have to google search for a FAT23 formatting tool. So take your data off the drive. Format the drive, put your files back on the drive and your good to go.
*************CAUTION************
There is a 4GB per file size limitation with FAT32!
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
When I turn on the ps3 it says hardisk corrupt. It doesn't restore it repeats the cycle over n over again What do I do??
there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot..
click here to download
Dec 08, 2010 | Sony Playstation 3 (PS3) Console
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Will not load a saved game from hardisk.
i had a bit of the same problem. For me it would freeze when i was loading them. I ended going back to the last good save and reloading it, deleting the old, and saving new files. Hope this helps.
Mar 22, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont pull the disk into the player
prior to the issue u facing basically is improper shut down of ps3 causing the ps3 operating system corrupted .1)back up your save game and the rest.Then format hardisk then restore back up .It will help to improve this fault.good luck .visit you tube how to format ps3 and back up .Pls rate me.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 can't be rebuild database cause no hardisk found
Bad Drive or either your Files are corrupted. Would recommend getting a laptop hdd and seeing what happens.
Jul 25, 2009 | Sony PlayStation® 3 (80GB) Console
There is a blue screen then it shuts down
i have this problem before, actually there are many causing blue screen. it might be the memory, hardisk, and the corruption of windows files etc. for you check first your hardisk if detected in your bios setup. if hardisk detected run safemode. then repair your windows.
Jun 25, 2009 | Toshiba Satellite A10-S100 Notebook
Dell b130 restarting all the time
hi buddy!
1. Go to bios setup look if the computer see the hardisk and you setup the first boot priority is hardisk.if you encounter the same problem.
2. Maybe your operating system have corrupt then you try to reprogram the hardisk. if they same problem apear
3. Your hardisk have a problem you try to change a new one
bochard_20
May 16, 2008 | Dell Inspiron B130 Notebook
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
