Samsung pcj522r blue converence
Where can I get the ic,s? Are they on a board to replace? Can you tell me where they might be located?
  • Ken Jun 07, 2008
    Unless they are on one of the three boards on the bottom I have not seen them. I took the back off and seen nothing but the tops of the crt.
  • 8,617 Answers
You can get the replacement Ics at the following link you need two STK392-040 ICs they are located on the Convergence board that should be mounted on the upper right side of the set above the deflection board. You will notice two large Black Ics with STK392-040 stamped on them. Heres the link to get the new ICs and free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jun 07, 2008
  • Sonny Berry
    Sonny Berry Jun 07, 2008
    Is your model the PCJ522R? let me know and I will post a picture of the board theyre one
Blue converence was intermitten now out on sides
If the IC's say have STK printed on them, then they are the convergence IC' s. should be three of them, replace all 3 , and the burned green coils, sometimes these burn as they supply the volts to the STK's. good luck, be safe..
Mar 11, 2009 | Sony KP-61V45 61" Rear Projection...
Kp46v15 converence
You need to replace STK4278-L quantity 2 on D board
Above part is available in part store.
Mar 02, 2009 | Sony KP-61V45 61" Rear Projection...
Samsung pcj522r
I am famillar with PTS, they would have tested The ICs first. I believe you will find the trouble lies in the DCU I have seen a good many of those needing replacement.
Jul 26, 2008 | Televison & Video
Samsung pcj522r
I just posted a response so you can locate the ICs
Jun 07, 2008 | Televison & Video
Blue convergence
yes you can just replace the board as a unit , but they are pretty exspensive compared to replacing the ICs as the ICs are what wear out.
Jun 07, 2008 | Samsung PCJ522R 52" Rear Projection...
No blue convergance
need to replace the convergence ICs. If you need a link to get replacement ICs let me know.
PCJ522R 52 /Power Deflection Board
we can give you a quote on what we can rebuild your deflection board for if you go to this link and send us an email request stating model nuber and part number of the board you need rebuilt. all our boards are completely rebuilt and are guaranteed.
Heres the link.
Mar 24, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
T.V.
Afraid you have the Bad Samsung set The convergance Ic's are mounted below ot a differant board that I described. If you are good at soldering simply replace the Ic's STK392-040 there are two, if you simply want to replace the entire board the part number for youre set is AA95-00055E and it's about $250.00
Feb 13, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R Pictures is completely shaded with yellow
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Oct 25, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
