Question about Mitsubishi VS-60607 TV
The front cover that diffuses the color came off during a move and broke. The T.V. still works ,but we need to replace the front cover.
    Novelist:
  • 85 Answers
Ljnorris1,
A new replacement screen for your model will cost nearly the same as a new LCD in a comparable size. Keep watching web sites like craigslist, eBay, etc. and you will find in time someone either giving theirs away or selling it dirt cheap and you can swap the screen.
-Chris
Posted on Oct 24, 2010
SOURCE:
When I changed Pentair Whiperflo motor with new Impeller & Diffuser seals the new motor shaft does not turn. Diffuser is pressing against Impellor not allowing it to rotate. What is wrong ?
Take the Diffuser off and run it if the impeller turns then might be tightening the Diffuser too much, it just needs to not move, doesnt really need a super waterproof seal or anything like that. If it still doesnt turn with the Diffuser off it might have locked up when replacing the Impeller, you can try to turn the impeller manually or remove the cover plate on the back of the moter and turn the shaft manually back there. OOoorr you broke it
Aug 03, 2015 | Pentair 2.0 Hp Whisperflo Pump
Young living aria diffuser not misting
I am having the same problem. I have no misting at all, only music and colors. I am going to try moving the glass spout so it's opposite the plastic spout--i read that somewhere. I'm also going to start over again with filtered water. I had gotten into the habit of just reflilling and adding more oils. hope this works and helps you too!!
Nov 27, 2012 | Young Living Aria Ultrasonic Diffuser
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
I recently moved and the movers broke the front screen of our Sony KDF46E3000 rear projection TV. Is that surface screen available for replacement? Can I do it?
There are two layers in front screen, check both layers are damaged or not.
Part numbers are as follows:
321007211 ... PLATE (E46L), DIFFUSION (KDF-46E3000 ONLY) [front layer] price is $148
321007311 ... PLATE (E46F), DIFFUSION (KDF-46E3000 ONLY) price is $128
Available in Sony Part Store, put part number in search box, hit enter to get result.
Yes, average handy person can replace it, need to take off front screen frame by removing screws at rear sides of tv.
Hope these info will help you.
Thanks.
Jan 03, 2011 | Sony KDF46E3000 46" Television
Makes loud noise during the spin cycle.
no loud noises water will drain, just belt broke plastic piece needs to come off so I can replace belt.
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Need to replace the front bumper cover on a 1995 ford escort
its just the bumper cover.. once you buy the bumper cover it will replace your broke one,, however you my need to buy a bumpercover support..i think its only about $30 more..good luck keith...
Mar 15, 2009 | 1995 Ford Escort
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Printer Cartridge cover broke off
No, sorry. Small parts are not available.
Feb 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
