Question about GE WSXH208A Front Load Washer
My frnt loaderis not drainin and speedin l - GE WSXH208A Front Load Washer
    President:
  • 1,932 Answers
The draining problem may be due to the drain pump being clogged.
Follow the below steps:
The drain plug is on the front of this washer - you can see it without removing anything - there is a small 5"x3" panel on the front bottom that you pull out and then the plug twists free - have a large pan ready and unsrew slowly - water will come gushing out - have towels at the ready!
There are 2 screws on the bottom of the larger bottom front panel - remove these and you can see inside
you will see the drain plug housing is connected to the water pump and there are two hoses connected to the housing and the pump one coming from the washer to the drain plug and one going from the pump to your drain.
Remove the hoses carefully - I used plyers to pinch the clamps together.
the hardest part of this is removing the drain plug housing and pump - because it seems like you should be able to just remove the pump - but you can not!!
There are two screws holding in the housing and pump - remove them and the whole thing pulls clear.
Once out you can make sure there is not more coins or anything else in the thing. Three screws hold the housing to the pump - mark these with a sharpie before you remove them - because once it is off there are multiple ways to re attach it.
Once free of the drain plug housing spin the pump a few times and put it all back together.
You can get the exploded view from below website http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/G0212152-00003.png
And for speeding up check the belt tension.Due to running the belt tension goes and during the spin cycle it slip off and speed reduces.
Thank You
Posted on Oct 24, 2010
6ya staff
SOURCE:
86 toy camry vibration frnt rt
Check your tires for lumps or flat spots, if you don't find any then jack the wheel up and grab top and bottom and try shaking the wheel, This will show if anything is loose, it could be a worn tie rod, Bearing or balljoint. Also check for any loose bolts.
Mar 08, 2012 | Toyota Camry Cars & Trucks
Connector pin color code and connection
ok i have one in my hands and it goes like this blue w white stripe ant cont green rear lft purple rear rt gray frnt rt white frnt lft red pos yellow fuse filter black neg thats what my deck shows and it isnt hacked yet good luck
Nov 25, 2010 | Kenwood Car Audio & Video
2005 chevy colorado whole frnt left side lights
The inside light is blinking quickly because the front blinker light is out. I'm afraid that without more info I can't tell you why the lights are out.
Jun 26, 2010 | 2005 Chevrolet Colorado
Peg Perego toy how do you test other parts if its not the battery
first of all test the battery and the charger with a multimeter and make sure that it is showing at least 12v
Oct 11, 2009 | Peg Perego John Deere Gator HPX
(4x4).. frnt driver wheel wiggles badly
wheels bearings? loose ball joints?
Apr 08, 2009 | 1990 GMC Sierra
Comp2 better picture quality than frnt but comp2 has no sound
you will need to change a setting
but to know the settings that are required and what you should not be doing with the input of the game will require alot of typing to you , to tell you important information
if you want to know what to change you will need to give me a fixya , because everything else just hurts our score an makes us not to want to help any more or at all, sorry but this is fixyas doing
otherwise I will be glad to give you the info
electech
Nov 08, 2008 | RCA 32F530T 32" TV
Drivers side frnt/rear turn signals
Always check fuses first then flashers then bulbs.
Jul 17, 2008 | 1995 Oldsmobile Cutlass Supreme
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
GE WSXH208A Front Load Washer Logo
19 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
