Question about Honeywell Programmable Thermostat Heater
Wiring a programmable thermostat for baseboard heater
I am changing the thermostat with a programmable one and the problem is there is 2 heaters and one thermostat.
There is a set of red, black, and ground wire coming from the 2 heaters and there is the power wire that also has red,black and a ground.
I am just wonder how to wiring the new programmable thermosat that only has 2 black wires
in total there is 3 red wires , 3 black wires and 3 ground wires .
What do I do ???
Any help would be great
  • Don Berry May 11, 2010
    You may have already figured this one out by now. If you still need help let me know if this is a 24v thermostat controlling 2 gas fired furnaces or if it is another arrangement.
    Habit-Forming:
  • 117 Answers
The red and black is power and neutral. Green is just for the ground and that should tie into the ground wire for breaker or power wire .
The 2 black wire from thermostat should tie into the two red and black wire from your heater.
Just imagine you are wiring 1 heater to thermostat and just add the the next heater the same way
Posted on May 19, 2017
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
SOURCE: marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Posted on Nov 19, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 15 Answers
SOURCE: Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Posted on Jan 26, 2009
  • 10 Answers
SOURCE: Farenheat baseboard heater F2544
You should have a licensed electrician connect this for you.
You did not specify the voltage. Baseboard heat comes in different voltages. If you connect a 240v unit to 110v it will work but only put out half of it's heat.
If you connect a 110v unit to 240v you will start an instant fire.
There should not be a thermostat on the unit and another on the wall. You can buy units for each application. You are probably looking at the thermistor which is a safety device which opens the circuit when there is too much heat. It must remain wired in series with the heat coil.
Also note that it is a violation of the National Electric code to install electric baseboard heat underneath an existing outlet. It is also common sense to not install it under drapes or near anything else combustible.
Posted on Feb 09, 2009
How do I connect two baseboard heaters to a programmable thermostat?
You have switched 2 of the wires, reverse them.. If you had it working once, then it will work again
Apr 12, 2013 | Honeywell Heating & Cooling
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Installing a cadet softheat hydrondic baseboard heater on 12-2 wire on 20 double switched breaker. Is this possible? I was told I could change the white wire to black giving me one black to each prong of...
Yes it is acceptable and common practice. You do not need a neutral on a 220 Volt circuit. Just wrap it with black electrical tape so anyone who gets into the wiring later will know that both are hot. This is accepted by the National Electrical Code.
Feb 13, 2011 | Cadet Manufacturing EBHA1000W The EBHA...
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Heating & Cooling Logo
61 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
