Question about Nikon COOLPIX S8 Digital Camera
I need software to install in my pc. i am using Nikon COOLPIX S8 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Posted on Jun 22, 2011
SOURCE:
Have no disk to install program for camera. is there one that can be downloaded
Here is the page to download the software: http://www.nikonusa.com/Nikon-Products/Product/Compact-Digital-Cameras/26198/COOLPIX-L22.html#tab-ProductDetail.ProductTabs.Software
Alternatively, you could just explore it as if it were a external drive once you've plugged it in.
Mar 28, 2011 | Nikon Coolpix L22BLUE Digital Camera
I need to install nikon coolpix l18 on my computer but i do not have the installaion CD what can i do?
Please check the nikon site to obtain the software for the camera. I shall give the link below:<br /> <br /> <a href="http://www.nikonusa.com/Find-Your-Nikon/Product-Archive/Digital-Camera/25596/COOLPIX-L18.html">http://www.nikonusa.com/Find-Your-Nikon/Product-Archive/Digital-Camera/25596/COOLPIX-L18.html</a><br /> <br /> log on and get to the software download to download.
Aug 31, 2010 | Nikon COOLPIX L18 Digital Camera
I have installed the Nikon Transfer software and am using the usb port connector. All I get is "the camera is busy" and zero program showing up in the dialog box where you select "always use this program"....
I had the same problem with the same camera. What worked for my pc was to start the Nikon Transfer software, select the camera and press the "start transfer" button. Nothing happens for about 6-7 minutes, but after that the transfer starts.
My pc: XP SP3
Camera: Coolpix L100
Nikon Transfer: ver. 1.3.0 (i used the software that came with the camera not the up to date version 1.5.3, but it might work with that version also
Jun 29, 2010 | Nikon COOLPIX L100 Digital Camera
Want to retrieve my pics lost in nikon cool pix s8
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead. you can then download a file recovery program and use the program to scan the memory card and then recover lost pics
http://filerecoveryblog.blogspot.sg/2011/09/how-to-recover-deleted-photos-from.html
Feb 10, 2010 | Cameras
Nikon coolpix S8 lens error
This is a pretty common problem with the coolpix range. Basically it means the lens has had some issue while driving in or out of the camera body, in some cases a simple tap on the camera side(not recommended by me) can fix the problem, in others you will have to send the camera to nikon to fix it but it will fall outside of warranty as its not considered a normal camera error.
Sep 06, 2008 | Nikon COOLPIX L18 Digital Camera
Lens cover error
I have a solution for Nikon coolpix S5/S6. I am not shure but it might be similar for S8, You can try my document "nikon s5 s6 lens cover error repair.doc"  uploaded on site
http://www.esnips.com/web/papputatiyasStuff
Regards
Mukesh
Aug 03, 2008 | Nikon Coolpix S3 Digital Camera
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Jun 15, 2008 | Nikon COOLPIX S5 Digital Camera
Apr 20, 2008 | Nikon Coolpix 4300 Digital Camera
Lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 18, 2007 | Nikon COOLPIX S8 Digital Camera
Nikon COOLPIX S8 Digital Camera Logo
49 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
