Question about Samsung PCJ522R 52" Rear Projection Television
Blue convergence What are they? Where are they located, can just replacing the board work? Have any idea of the part number?
  • Samsung Master
  • 8,617 Answers
Yes you can just replace the board as a unit , but they are pretty exspensive compared to replacing the ICs as the ICs are what wear out.
Posted on Jun 07, 2008
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
Convergence problem
What model number of Pioneer TV set do you have? There should be a large heat sink or something metal with cooling fins on it where the IC's might be mounted away from you so you will need to look at the other side of the heat sink. Replace those IC's and you will be able or should be able to adjust the set providing you have not tweaked it too much before repairing the problem. Good luck
Feb 11, 2008 | Televison & Video
Turns on has blue light thats it no sound or picture
convergance amps are failing and need to be replaced along with the 2 burnt resistors not a bad job they are locate on a smaal board in front behind the front panel on a large heat sink you can take the board out and work on it
Nov 28, 2009 | JVC AV-56WP74 56" Rear Projection...
I replaced the convergence board but still have the same problem.
The problem is not with the convergence board. Its the Convergence ICs which are located on the sub board. Use two stk392-040 ICs as your model probably has the 392-010 now. But you can get two new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link you will need two STK392-040 Convergence ICs.
http://servicemanuals.vstore.ca/
May 22, 2008 | Samsung HCM4215W 42" Rear Projection...
Convergence board
do not remove the back panel to that model with the power cord still plugged in cause if you do the digital section of the TV will be completely wiped out. The convergence board is in the front behind the speaker grille and small access panel its the first board after the access panel its on the right side rectangle board. You can get a convergence board at the following link just leave an email with your model number and what your needing. I work there as a support tech and they just got those boards in yesterday and havent even listed them yet. Heres the link.
May 21, 2008 | JVC AV-48WP74 48" Rear Projection...
Yes i need more help on these opto-couplers
The halo effect is due to the green and blue CRT coolant being congealed this is a common problem. Red will not have the same condition. As for the opto-couplers they are located on the large signal board in the middle of the board all lined up in a row they will have board location numbers of 7412, 7406 and 7413 . 7412 is usually the culprit the part numbers for 7412 is 9322-105-14682 7406 and 7413 are the same part number 9338-894-15682
May 15, 2008 | Televison & Video
Convergence issue with blue
You need to replace the convergence Ics located up front behind the speaker grille numbers STK392-110 you can get replacements at the following link and they provide free tech support and instalation instructions with pictures. heres the link.
May 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
What is the model number of your set? Post the make and model number and I should be able to help you locate a replacement board for you.
Feb 02, 2008 | Televison & Video
Double Vision
Unfortunately, the complete convergence amp board is no longer available from Samsung. But the board is available from ptscorp.com. Go to the website, get the telephone number, ask them what convergence Amp board you need and if they have it. If you know how to solder and unsolder, you can simply change the convergence amp IC's, on the main convergence board. The IC number if the IC's is STK392-040 Good Luck.
Jun 16, 2007 | Samsung HCN473W 47" Rear Projection...
Akai 4298 projection tv
Most likely, this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Hope this helps ...
Aug 29, 2006 | Akai PT4298HD Rear Projection Television
Samsung PCJ522R 52" Rear Projection Television Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
