Question about ASUS Eee 4G Notebook
Can i upgrade the hardisk of my asus eee pc series laptop to a higher memory?
  • 707 Answers
Most EEE PCs use 533/667 MHz DDR2 RAM via a standard SO-DIMM module, which can be swapped out. The 700 and 701SDX have RAM soldered to the motherboard.
The black model EEEPC 4G SURF (4GS-PK008), and newer white models (4GS-W010) have a removable panel on their underside that allows the user to change the RAM without fully disassembling the system. The older white models (4GS-W010) lack this access panel, and require some disassembly in order to access the RAM.[57]
The hardware supports up to 4 GB (2 GB for the 1000 series, and some of the 900 series), but the preinstalled Xandros kernel of the 700 series only supports up to 1 GB
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Posted on Oct 24, 2010
SOURCE:
My notebook hardisk is too small (8GB, ASUS) can I upgrade my Hardisk?
Yes you can BUT the maximum size you can update the hard drive depends upon the BIOS.
Alternative you can use an external USB hard drive to store your data and this is not restricted by the BIOS.
Jun 26, 2011 | ASUS Eee 4G Notebook
Change hard disk in Eee PC 4G
its a series of chips soldered directly to the motherboard and is not user upgradable without very special equipment. Most people add USB Hard Drives or Thumb Drives to increase the storage on an EEE PC.
Feb 04, 2011 | ASUS Eee 4G Notebook
Need to replace hardisk but i could not open the hardisk
http://www.youtube.com/results?search_query=ASUS+Eee+PC+4G+PC+Notebook+how+to+open&aq=f
this is the link to know how to open this
thanks sir
May 09, 2010 | ASUS Eee 4G Notebook
Is it possible to up grade a asus eee fizz book
Yes it is possible to upgrade the ram and the harddrive, there will be little blanking plates on the back of the laptop, they are held in by small screws, undo the screws and you will have access to the memory and the harddrive. If you are unsure take it to a pc store and ask if they could find out what type of memory and harddrive is needed to upgrade. hope this helps.
Mar 24, 2010 | ASUS Eee PC 900 Notebook
My screen won´t turn on
you need do check:
1) find your laptop RAM memory stick location reference:
http://myeeeguides.wordpress.com/2008/10/15/eee-pc-1000h-ram-upgrade/
2) take out the RAM clean pins then reseat it back, turn on, if still dark screen your laptop got trouble at onboard memory, need send to repair.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 22, 2009 | ASUS Eee PC 1000H Laptop
Toshiba satellite
#1 answer; add RAM. What's your system specs?
Feb 26, 2009 | Toshiba Satellite 1805-S274 Notebook
Asus eee pc series
have you updated anything
such as memory or operating system
and can you use an external mouse on laptop
Jan 22, 2009 | ASUS Eee PC 900 Notebook
To upgrade my Asus Eeepc 4G
The only way you can add space is for you to use an external HDD because an Eee PC has a built-in hard drive that cannot be upgraded.
Dec 07, 2008 | ASUS Eee 4G Notebook
Pls help
configure wireless network
Press Fn (Function key) at the lower left hand corner and F2 at the same time.
select Internet tab>>click on wireless networks.
select the wireless network that you have, and click connect.
this is where you need to know what kind of encryption you have on the wirelss network.
select encryption type. (WEP, WPA or other).
enter passkey for the network, and Press OK
Sep 12, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
