Question about HP Photosmart C4280 All-in-One InkJet Printer
When I want to print something, if I go to file then print, it says offline, bot when I click on the C4200 series( copy 1) it will print BUT brints VERY small. Am I supposed to doing something diff? Thisis a diff printer for me, but the other was just like it. I do not have a book etc for this. It takkes about three papers for a recipe prints very small in L upper corner.
    Guru:
  • 731 Answers
  1. Click start --> Control panel --> Printer and faxes
  2. Right click on printer 'C4200 series' and select 'Set as default printer'.
  3. Right click again on the same printer icon and select 'Use printer Online'.
  4. Try Printing.
  5. You can delete the icon that says 'C4200 series(copy1)' if you are not using it.
Regards
Riztech
Posted on Oct 24, 2010
  • 707 Answers
SOUNDS LIKE YOU HAVE IT SET TO PRINT ENVELOPES
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
  • vick_c Oct 24, 2010
    I dont know how it got on printing envelope help please.
4 Suggested Answers
SOURCE:
  • 75 Answers
SOURCE: HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Posted on Jan 07, 2009
  • 564 Answers
SOURCE: Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 31, 2009
SOURCE: HP Deskjet 3500 series, my printer keeps telling
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Posted on Jan 02, 2010
It states that the printer is offline. i have this machine for my company so how am i able to put it back online?
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
Jan 13, 2011 | Kyocera Mita KM-5035 Printer
Tip
Printer Offline Error
3. Click on FILE.
7. Try printing.
WINDOWS XP
3. Click on FILE.
7. Try printing.
on Jun 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
My printer status show offline eventhoungh i'm online.It can copy(photostat) the document but it cannot print.I alrerady change the printer port but it still offline.My printer is HP Deskjet...
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 26, 2010 | HP Deskjet F340 All-In-One Printer
My HP Photosmart C4200 All-in-One won't scan. It keeps giving me a message, USB not connected but it is because I can copy and print. HELP!
do you have the correct drivers downloaded for scanning? go to this page <A href="http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&amp;h_lang=en&amp;h_client=s-s-r2515-1&amp;h_cc=us&amp;h_query=HP+Photosmart+C4200+All%2din%2dOne+Printer+series">http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&amp;h_lang=en&amp;h_client=s-s-r2515-1&amp;h_cc=us&amp;h_query=HP+Photosmart+C4200+All%2din%2dOne+Printer+series</A>&nbsp;and find your printer and go throught the diagnostics tool, it wil fix it for you
Aug 30, 2010 | Computers & Internet
I am trying to install a HP Photosmart C4200 Series.
If you are not able to get the software drivers for the C4200 Series
then Click on the following Link
HP C4200 Series
Select your Product and then select the Software & Driver downloads option from the left
cheers
Tx
Mar 01, 2010 | HP Office Equipment & Supplies
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Copying on HP photosmart C4200 all-on-one series
  1. Check that the reservoir under the cartridges is not full.(This is a V shaped bucket sitting under where the print head parks.)
  2. Clean the plastic the two cartridges sit in with alcohol and a cotton swab. Especially where the copper makes contact.
  3. Clean the ink from the copper portion of the cartridges themselves or replace the cartriges with new ones...
Jul 24, 2008 | HP Office Equipment & Supplies
I have installed an HP Photosmart C4200 all in one series to my laptop and all was ok initially. Now everytime I want to print it re-installs the printer and currently I have three installed, the original...
Dont Uninstall the driver remove the extra copy from the printer and fax wizard which can be found in control panel this will not remove the printer drivers but the extra copies
Apr 22, 2008 | Office Equipment & Supplies
Printer is offline
Please tell me how to have my printer online.
Apr 16, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C4280 All-in-One InkJet Printer Logo
290 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
