Question about Logitech Cordless Freedom ITouch (967092-0403) Keyboard
My F1-F12 keys suddenly aren't working. I've tried reconnecting the keyboard to the wireless hub. No idea what to do now. Is this fixable and how?
    Genius:
  • 1,189 Answers
Hi greg736, try going to this website, and "Update the Drivers; click on: http://www.pchelpsoft.com/hh-online/p/Logitech/device?gclid=CJqhxZnA6qQCFU465QodQibZ1Q "Give the solution a rating if it help! Thanks for using Fix'Ya."
Posted on Oct 24, 2010
  • 707 Answers
IF YOU'RE TALKING ABOUT A PRE-BOOT SITUATION MOST WIRELESS KEYBOARDS WON'T WORK. YOU NEED A SERIAL KEYBOARD. HOP IT HELPS.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
SOURCE:
I have an emachine newer one cant seem to turn on wireless switch so i can connect to wifi
Look for a wireless icon similar to the attached picture on the keyboard, it locates usually among F1 to F12 keys, if you don't see anything similar from F1 to F12, then try looking from 1 to 9 keys. Once it's located, press and hold down the Fn key on the keyboard and press the key with the icon (i.e. wireless icon) simultaneously for a couple of seconds, this will turn on and off the wireless function of your system. Let me know if you need further help with the model number of your emachine. Good Luck.
Aug 27, 2013 | E-Machines eMachines Desktop PC
Lost wireless connection in ubuntu laptop
Try recycling the router by unplugging it and plugging it back up.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Jun 02, 2012 | Computers & Internet
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
May 11, 2012 | E-Machines M5312 Notebook
Hi! All i have Amilo li2727 and using windows 7. my wireless net device doesnot want to turn on what must i do.
Normally there is a switch on the side or front that turns the wireless on. The FN function key located at the lower left portion of the keyboard toggles the wireless on and off if the switch is on. Normally you would Press and Hold the Fn function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it will have the icon of a tower with the wireless signal )))).
May 06, 2012 | Computers & Internet
Wifi problems with Dell Inspiron E1705
LOL, sounds like you didn't hit the correct key or keystrokes.
First of all look in front and on the sides for the Wireless Switch and make sure it is turned on. Then once it is on you can toggle the wireless on or off by Keystrokes. Press and Hold the FN key located at the lower left portion of the keyboard, then hit the corresponding F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of the wireless signal )))) or it will have the icon of a tower with the wireless signal )))). Normally when the correct keystrokes is hit the screen will display Wireless On or Wireless Off.
May 05, 2012 | Dell Inspiron E1705 Notebook
My Wi-Fi on Lenova Think Pad T60 is not working. I tried to update the drivers. Still not working.
What is it doing? Still not working could mean a lot of things!!! Is the computer connected to the wireless network? You've got to connect to the network before you can do anything. And most times the problem with connecting to the network is people key the network key or password wrong so the wireless just keeps on polling trying to connect.
Do you have the wireless turned on on the notepad? Sometimes there might be a wireless switch somewhere that you have to turn on. Also most times you can toggle the wireless On and Off by hitting the FN Function key and the corresponding F1 thru F12 key that toggles the wireless. Most times the correct F1 thru F12 key will have a wireless icon signal on it sorta like ))))) or it may show a tower with the signals. Once you find the correct F1 thru F12 key to press then Press and Hold the FN Function key then hit the correct F1 thru F12 key. If you look at your screen most times it will let you know if you've toggled the wireless by displaying Wireless On or Wireless Off.
Mar 29, 2012 | Computers & Internet
I use MacBook Pro (OS X version 10.5.8) in combination with LCD TV, wireless mouse and new Apple wireless keyboard. The problem is that function keys of the wireless keyboard do not respond in a same way...
Make sure to run all available software updates as there's probably a firmware update for your keyboard you need to download.
If there isn't or the problem persists afterwards, you'll need to go into Apple Menu > System Preferences > Keyboard and Mouse > Keyboard and uncheck 'Use all F1, F2 etc. keys as standard function keys.'
Nov 06, 2010 | Apple Wireless Keyboard
Wireless not working
Make sure the wireless pickup for the laptop, integrated or separate is installed properly and is enabled. The laptop should have a function key (check your manual) like "FN". Pressing this key and usually a function key (F1-F12) should tell you if the wireless function if built in is enabled. If the wireless pickup is USB or a PCMCIA, check the installation again and make sure the hardware is compatible with each other. It's usually not a good idea to mix vendors like using a Linksys router with a Netgear pickup.
Aug 23, 2009 | Belinea Computers & Internet
Connect wireless to acer aspier 4520
the function key if you look by the windows key it has Microsoft logo there should be a key that's says Fn which is the function key if you press and hold that down it activates the second mode on your keyboard if you look on the buttons you should see second symbol's mostly on the F1 -F12 keys which look for the wireless symbol as soon as you let go of the fn key your keyboard returns to normal hope this helps
Jul 27, 2009 | Acer Computers & Internet
F keys suddenly not working
The "F mode" button toggles on and off the F keys. If you press it (accidentally) as I did, the keys will no longer function.
Simply press the "F mode" key again (it is directly above the "End->" key between F12 and Insert on this model keyboard) and functionality will be restored.
Apr 08, 2009 | Logitech Computers & Internet
Open Questions:
$$^$*& Amazon Prime rEfUnD pHoNe #{+1-85O-8I2-4OO9 how to get refund from amazon prime? Amazon Prime Membership Cancellation Phone Number +1-85O-8I2-4OO9. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Amazon Computers & Internet
See all Logitech Cordless Freedom ITouch (967092-0403) Questions
Logitech Cordless Freedom ITouch (967092-0403) Keyboard Logo
76 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
