Question about Compaq Armada 110 Notebook
How do you add more RAM in a Compaq Armada 110
    New Friend:
  • 56 Answers
If you have a slot to add a ram then u can go through the manuals of the motherbord
Posted on Oct 24, 2010
SOURCE:
Compaq armada 110 user manual
Hi Misa,
Here's the user guide in pdf.If you're using Windows XP here's the user guide,and for Windows 7 here it is.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Compaq Armada 110 Notebook
How do add ram or is it even possible on this unit
Hello, yes it's possible. There are 2 memory slots under the keyboard. Take a look at
http://www.ehow.com/how_6234021_install-memory-compaq-armada-e500.html
for quite a lot of info on the Armada E500. Also youtube for some useful info. if you type 'Compaq Armada E500' into the search box.
Regards
nicam49
Oct 30, 2010 | Compaq Armada E500 Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Oct 15, 2010 | Compaq Armada 110 Notebook
Compaq armada 110 battery not charging at all laptop works on power supply perfectly but when cable removed no charge in battery, new battery purchased same problem how can i resolve please
I'm sorry to here this but in this case you must bring the laptop in the manufacturers service center because they have to replace batt terminals for it to charge them again. It happened to my cousins laptop.
Apr 06, 2010 | Compaq Armada 110 Notebook
Compaq armada 110
Verify that you have the required 18.5VDC coming into the laptop by the AC/DC converter. take a multimeter and put the black lead on the outside of the connector and the red on the inside..you should have between 18.5-19VDC
Nov 26, 2008 | Compaq Armada 110 Notebook
Compaq Armada 110 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
