Question about Xerox WorkCentre XE90FX Laser Printer
WorkCentre XE90FX copy service error ?
I am getting a copy service error E7 and hit the green copy button and get 03.
seems to be heating up, and toner seems full, no jams, has paper. I tried the pink, auto , pink, auto, 1x10, 4x1, green x1, pink x2, buttons and resets with same error.Any Ideas? Thanks in advance.
    President:
  • 2,072 Answers
Most likely the fuser sensor is out of its mounting or the actuator is.
That's really difficult to get out, Have to disassemble the machine. If you do that make sure you have the proper torx tools and patience.
Not the easiest machine to work on. be very careful disconnecting any ribbon cables. The on to the scanner is easily damaged.
Posted on Jun 07, 2008
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
My xerox worcentre 103f shows the errors e7 - 15 where can I get a list with the code
The error code e7-15 is a copy lamp problem. There is a list of error codes for the Workcentre 100 series at this link.
http://www.partsdrop.com/pages/XD100inf.html
Jun 10, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I am getting copy service error also H4.can you please HELP!!
Hi
try reseting the H code:
· Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE.
· The display should go blank.
· Then enter 14 with the copy count keys and press START.
· If the machine does not turn off and back on by itself - then turn it Off and back on.
· See if the H code comes back.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | Xerox WorkCentre XE90FX Laser Printer
F6 error appear show the xerox xe90fx
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Give this a try, the code is a fuser not warming code. This could resolve it.
Regards,
Jeep Brainy
Aug 10, 2009 | Xerox WorkCentre XE90FX Laser Printer
I am getting an error message "H-4" on my copier. Xerox says that they do not service these anymore. ???
Well if you depend on Xerox service, then you have a problem. They are getting out of the service business. But there are tons of Xerox dealer service and independand service that service that product. But you do NOT need a service call. Do this reset and it will correct your problem. This WILL work.
  8. If the above steps do not clear the error code, repeat steps several times
Oct 21, 2008 | Xerox WorkCentre XD120f Copier
Xd 120f xerox
An E7 is related to the scanner. The lamp carriage is gettiing hung up on something or a cable has broken or popped off a pulley. What I have seen most of the times, is the lamp carriage is hitting the sensor that tells the machine the lamp is in the ready position. Biased to the left side of the machine. remove the platen glass and see if you can move the lamp fairly easily. And when movine it back to the left, pay attention if you feel it hitting something.
Also here is the procedure to clear the code.
Performing a Fault Reset 1 01 will reset your Scanner, and allow you to check the Scanner for broken parts as it moves.
  4. Press the [1's] Key to enter 1 in the LED Display, as if you were to make 1 copy.
  5. Press the green [Start] button. '00' will flash in the LED Display.
  6. Press the [1's] Key to enter 01 in the LED Display, as if you were to make 1 copy.
  7. Press the green [Start] button. '01' will be in the LED Display and '100%' will be selected.
  8. Lift the Document Cover.
  9. Press the green [Start] button. The Scanner Bar should move from left to right under the Platen Glass.
  10. Visually check the Scanner Bar as it is moving to make sure it runs all the way across.
  11. Check the Mirror that follows the Scanner Bar to see if it is broken or cracked. NOTE: If you need to see the Scanner Bar and Mirror move again, press the green [Start] button again.
  12. Press the pink [Clear] button four times.
  13. The WorkCentre should now warm up and come to ready.
Oct 13, 2008 | Xerox WorkCentre XD120f Copier
Error 7 , the copier seems to be stuck
Give this a try, Just 7 is not normal. Is there a letter appearing first?
But try this procedure.
Apr 08, 2008 | Xerox WorkCentre XD130DF Laser Printer
Machine stops and F6 appears
elem_1_spacer.gifGive this a try, the code is a fuser not warming code. This could resolve it.
Jan 13, 2008 | Xerox WorkCentre XE90FX Laser Printer
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
Xerox WorkCentre XE90FX Laser Printer Logo
154 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
