Question about HP OfficeJet 6110 All-In-One InkJet Printer
What do you do if the printer says "Remove and check cartridge." I already removed the print cartridges but it didn't work.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
you need to replace your cartridge with a new one or an olders refilled
If i help you pls vote me
Posted on Nov 01, 2010
SOURCE:
BLACK CARTRIDGE PRINTS IN SPASMS BUT COLOUR CARTRIDGE PRINTS FINE.
I didn't get your question,even I am trying to give you solution. Switch on the printer, left top cover wait until carriage arrive at middle, remove mono cartridge, take out swab nozzle area with good cotton or ear buds adding with alcohol(solvent) gently in one direction,repeat three to four times & shake well and see ink coming out from nozzle area?, clean nozzle area with tissue paper put it back & check for print..
Feb 04, 2012 | HP DeskJet 5150 InkJet Printer
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
Remove check print cartridges
Are you sure you are using genuine HP print cartridges - I know my hp printer will not print with refilled cartridges. I have also checked this site - it may help you
HP PSC 2510XI All-In-One InkJet Printer - "Remove check cartridge" issues ... Remove and Check Print Cartridges . The printer will not print. The message does ... www.fixya.com/search/p378796-hp_psc_2510xi_all_in_one_inkjet_printer/remove_check_cartridge www.fixya.com/search/p378796-hp_psc_2510xi_all_in_one_inkjet_printer/remove_check_cartridge
Feb 02, 2012 | HP PSC 2510 All-In-One InkJet Printer
Unable to print or delete a document
  • 1
    Remove the cartridges from the F380 printer.
  • 2
    Position the cartridges so they are right side up and the gold leads are facing you.
  • 3
    Place a small piece of tape over the gold contact in the top left corner of each cartridge.
  • 4
    Place the cartridge back in the F380 printer. The printer automatically prints an alignment page.
  • 5
    Remove the cartridges. Place a piece of tape over the gold contact in the top right corner of each cartridge.
  • 6
    Place the cartridges back into the F380 printer. The F380 prints another alignment page.
  • 7
    Remove the cartridges from the printer. Remove both pieces of tape from each cartridge.
  • 8
    Insert the cartridges into the F380 printer. The printer prints a cartridge alignment page. Each cartridge is now recognized as a full ink cartridge.
  • Jun 16, 2011 | HP DeskJet F380 All-In-One Printer
    Won't print: "remove and check color cartridge"
    remove your new color cartridge and make sure you have removed the safety tape on the botton of the cartridge.
    Mar 07, 2010 | HP PSC 2110 Color Printer
    I changed the print cartridge and now it won't print my documents
    Most likely you left the tape on the new cartridges which protects the printhead. Remove the cartridges, pull the tape off and reinstall the cartridges. If the tape was already off, double check to make sure they are the right cartridges. Good luck!
    Feb 08, 2010 | HP Business InkJet 2800 Printer
    My KodakEasy Share 5300 will not print in black.
    92b8b47.jpgThe Kodak AiO printers 5000 series and ESP series PRINTHEADs has orange protective cap that need to be remove to fit on the printer carriage. For the ink cartridges 7b91cbc.jpgthere is also a orange protective cap.
    Issue that its not printing black and deep clean and removing the printhead and reinstalling the printhead (reseating printhead) is already done and still no black when printing. The printhead should be replace. For futher assistance call 1 800 421 6699 Kodak AiO printer support line
    Nov 16, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    New tri-color cartridge has a problem. I can't see what.
    I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
    Tri-color.
    And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
    Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
    Hp psc2410xi
    The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
    2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
      • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
        1. Clean the color cartridge contacts.
        2. Reinsert the color cartridge into the carriage and close the blue latch.
        3. Close the printer and wait 10 to 15 seconds.
        4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
      OR
      • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
        1. Reinsert the color cartridge.
        2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
        3. Clean the black or photo cartridge contacts.
        4. Reinsert the black or photo cartridge.
        5. Close the printer and wait 10 to 15 seconds.
        6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. Remove and then reinsert the cartridge indicated in the error message.
    2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    27 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
