Question about LG Washing Machines
My LG washing washing machine got problem..water pump always energize and out of control..I suspect the nain control board problem..how much this cost for repair? how much is the Controller board for LG washing machine model WF-TS999TC.
SOURCE:
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 713 Answers
SOURCE: My LG Washing Machine WF-T853A is putting black ru...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
Posted on May 15, 2010
  • 6028 Answers
SOURCE: where does the fabric softener
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Posted on Feb 13, 2011
  • 6277 Answers
SOURCE: lg washing machine WF TS
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Mar 25, 2011
My fuzzy logichas stoped spinning washes ok but no spin pls addvise if its easy fix thankyou
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.check for output when the cycles is in the SPIN mode, if absent the board is a suspect.
Check for moisture in the board, remove and reset all the connectors to the main board before the processor or the memory can be suspected.
Feb 06, 2013 | LG Washing Machines
LG FRONT LOAD 'WM2077' pumps water out as it's filling. What is wrong? How to fix?
Suspect that the main program controller unit is faulty as it seems to output to the wrong cycle so as to drain as it fills. You can remove the unit and check all the connections to the panel. Check the output to the drain pump and see if the voltage to the pump stops when the program is reset, if not there is short in the board.
Sep 04, 2012 | LG Washing Machines
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
In display shown FE
"FE" error code - over flow error
-Check water conection
-Check Water valve for proper operation
When the "FE" error code is displayed the drain pump will be turned on to pump the water out of the washing machine. LG Washing Machine Error Codes
This error code comes up when there is a over flow condition. The error is coming up because a part inside the washer has failed. I suspect the water valve on the back may be the culprit, it's fairly common.
Hope helps.
Aug 10, 2011 | Washing Machines
Water is not coming
If what was meant is the input water supply please check voltage on the inlet valve , if present the valve is faulty , if not the program controller is a suspect and needs a check on the driver. If this is the drain water problem check the voltage at the cycle end on the valve/pump of the drain . If present the valve/pump must be taken out and cleaned or replaced. if not the program controller is a suspect.
Jan 20, 2011 | LG Washing Machines
Water is not draining out
Check that the drain hose is not clogged.
Access to the drain pump and check the drain pump intake, that is probably filled with debris.
Ensure that the drain pump is working, the pump should be energized directly by a technician to test it.
If the drain pump is fine , and you already tested water level switch, then it is either a bad control board, or a lose contact on the drain pump wiring harness to control.
Feb 18, 2009 | LG WM2487H Front Load Washer
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Open Questions:
Washing Machines Logo
56 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
