Question about Dell Dimension 2350 PC Desktop
Desktop shusdown while trying to get to desktop
When I try to boot I go through start-up and before the desktop times out and is funstional, the computer powers down.
  • Ripcurl Nov 29, 2008
    Able to power computer up & get to desktop; after 2 minutes or so the machine shuts off. When I hit F8 during startup it sometimes makes it to the desktop & sometimes doesn't. This is my wife's computer - it isn't hooked up to the internet, & all she does is play mahjonng on it or word process recipes.
  • 86 Answers
Sounds like heatsink bracket has broken. my Dell 2350 has same problem. It is a plastic part that is used to clamp the heatsink onto the processor. The part number is 8T065 and is available on a couple of sites online for around $5.00. It is a fairly easy fix just make sure you save the two metal clips that go over the heatsink to use on the new bracket.
Posted on Dec 25, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
This is due to a safety mechanism with the processor.  The pc is probably overheating.  Unplug the computer.  Take the side panel off.  Check the black bracket that holds the heatsink (silver square with fins) and see if it is broken.  You will need heatsink grease and a replacement bracket.  The heatsink is what allows the heat to come from the processor and out the back of the computer.  It must be seated properly or the computer will shut down when it reaches a certain temperature.
Posted on Dec 11, 2008
How much
Posted on Jun 07, 2008
When i turn the computer on it beeps 4 times and repeats this, nothing comes up on the screen.
one of the periferals is defective (RAM, PCI card, video, CD or Hard Drive, etc...) remove everything that you can leaving just the board, CPU, one stick of RAM and power supply, than boot if all goes well, shutt down than re-plugg one thing at a time, than re-boot, start with the RAM modules (one stick of RAM at a time as well) to see which device is causing the failliure... if it is not booting on the first try, switch RAM modules by starting with only one RAM stick at a time...
Cheers!
Sep 18, 2011 | Dell Inspiron 537 ST PC Desktop
My computer won't start, it appears to have no power. For the past 2 weeks when ever I would start up it up I would have to constantly push the start button 3 to 5 times till it would power up. Now it...
Most likley you have a fried power supply. Try this first unplug the computer from the power cord for 5 minutes then plug back in and go into safe mode see how to go into safe mode below.
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52computers
Please Vote
Jan 10, 2011 | Gateway GT5014 PC Desktop
I have a Acer PC. My Pc won't load past the Windows Blue Splash Screen. When I try to go in via Safe Mode, it stops at the same place. I been trying everything ... through the recovery console. With no...
remove all dervices, pci cards, modem card, usb devices ect... except for the hard drive, the cd/dvd drive and video card, if applicable. go into bios (by holding down f1, f2, f10, or delete before windows starts to load. try each, for different computers use different buttons) and disable the sould card, modem/network card, if integrated, and any integrated components which are not absolutely necessary to boot.
try to boot. if that does not work, try using 1 stick of ram at a time, and try each stick,1 at a time until it boots.
if your computer boots when stripped down, then try reinstalling/reenablind each device, 1 at a time, until you find the device that is keeping it from booting.
if your computer will not boot when stripped down, you need a new motherboard.
Nov 06, 2010 | Acer Aspire™ T180 PC Desktop
After installing another HDD from another Packard Bell computer, the computer would not boot. This computer I recieved from a mate and I dont believe windows was removed, as I have tryed and failed...
if it is a sata Hdd you have to reinstall it ..cause the sata driver on the os ..is from the other computer ..or go to bios ..and in the drives feature..look for a function called AHCI and disable it ...
after that will boot with the windows installed..but you will have to reinstall the windows anyway ..and if it is a raid sata you need to insert a diskette with the sata driver during ..or disable the ahci function ..for to let it see the HDD ..if not all it will say is that the hdd was not found..or if you try to boot with this windows on it .will say that the media is missing ..
beter to set the defaults in the bios ..and after that look for that funstion to be disabled..or disable the raid sata ..and enable teh sata Ide..instead..it is the same thing ..and will pick up the sata hdd with no sweat ..
Aug 30, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
Dell Inspiron Desktop PC won't start up
Hit FN at boot then let me know what it does
Jan 14, 2010 | Dell Inspiron 530 Desktop Computer
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
My Hp a1630n does not start up. It does not boot,no beep, screen displays 'no signal'
If it is getting no power at all to the tower, your power supply is probably dead. If you are getting lights but no beeping then it may be a matter of resetting your motherboard. This would entail opening up the computer removing the power cord and removing (carefully) the small watch battery on the motherboard. After waiting about 30 minutes, put battery back in and try to power up. If it still dosen't boot up then it's time to start removing parts and keep trying to boot up until you have narrowed down what the problem is. If all is removed and still nothing. Your motherboard is probably bad. Good Luck.
Oct 25, 2009 | HP Pavilion a1630n PC Desktop
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
COMPUTER WILL NOT BOOT
This does not sound like a power supply issuse
Try This:
tap F8 while booting the PC
This should take you to the Advanced Boot option window
Use you up & down keys: Safe mode With Command propmts(Enter)
Operating System (Enter)
Sign in under your user name( or owner)
once at a command prompt (Black Screen)
Tyoe chkdsk /r (Enter)
You will get a message ( This valume is in use would you like to start a chkdsk on reboot (Y) (Enter) Reboot PC
This should start a chkdsk after the chkdsk is complete reboot the PC you should go to you profile (desktop with Icons)
Good Luck
Dr Geek MD
Feb 22, 2009 | Gateway GT5220 PC Desktop
Dell Dimension 2350 PC Desktop Logo
65 people viewed this question
Alun Cox
