Question about Koss KS4102 System
Video difficulty When we try to play a dvd, the screen rolls. We have had the system for 2 years and we have not changed anything - it worked fine before. Please help if you can. I can give you more info if you need it - I wasn't sure what you needed initially.
  • Koss Master
  • 5,568 Answers
You've probably given up on getting an answer since it has been some months but in case you haven't axed both yet . . .
You might try the DVD player on someone elses TV to isolate the problem to the player or the TV.  Or the reverse; one of the two is not synchronizing right and it is the TV's job to tweak itself to lock the picture from an external source.  It is unusual for any modern TV to have problems synchronizing with another device, even if they aren't too stable so I would suspect the DVD player first.
Posted on Oct 03, 2008
When a dvd movie is playing the screen keeps rolling. Is there any way that I can fix that by adjusting anything on or in the system itself..
rolling tv screens is an indication of a vertical hold problem
if there is a tab in the onscreen menu , use it to remove the sensitivity of the signal input from the dvd unit
if there is no such adjustment available then the problem may be the first signs of a tv problem so talk with a repair shop
Feb 19, 2017 | Televison & Video
Tv screen rolling vertically when trying to use my DVD player
that's a synch issue..is the cable tightly installed? do you need to have that on another channel, by chance?
Apr 28, 2008 | Apex Digital AD-1110W DVD Player
DVD won't play through DVD Player
2 questions. Did you finalize it when you burnt it? Did you record it as video dvd or a data dvd?
May 31, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Memorex DVD problem -- rollig screen on TV
How is the dvd player connected to the tv?
Mar 21, 2009 | Memorex MVD2050-BLK DVD Player
The dvd works fine but the vcr does not. the picture rolls.
The VCR is connected throug an audio/video cable (red, white and yellow) This happen because the electronic ciruitry on the combo "read" that the signal is going out to copy, and this devices have a copyraigh protection circuitry tat don't allow to do this, is not your fault, but making the connections like this, the systems automaticly activate this feature. If you can change the tv with one taht at least have the white and yellow RCA terminals, your problem will be solved definitevily.
Nov 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Blue screen during dvd play
The dvd player software that you're using maybe not supported by your vga card. Try to change your setting of the graphic card video option. Or try to play the dvds using different player.
Sep 21, 2008 | EliteGroup P4VMM2 Motherboard
Black screen instead of DVD playback
try changing the dvd drive speed in the system configuration, it may be at standard, change it to fast
Jun 25, 2008 | Sony PlayStation 2 (PS2) Console
Won't play purchased dvd's
i,d suggest laser head problem.
Dirty-weak laser unit. try a head cleaning disk.
Mike @ compurepair.
Feb 25, 2008 | Amphion Mediaworks T342 System
Screen displays "Error data" when trying to play a DVD
My understanding is that the DVD player uses a different lens to the CD player. So the DVD lens might need cleaning. A CD lens cleaner would not correct the DVD side.
Oct 04, 2017 | GoVideo DP8240 Portable DVD Player with...
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Koss KS4102 System Logo
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steve K
Carlos L. Burgos
Carlos L. Burgos
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
