Question about ASUS UX50VRMSX05 Notebook
I am setting up my new laptop and all the updates keep stalling my set-up. After performing the 3rd of 3 parts in installing it will wait for hours at the 100% before doing anything and a lot of the updates aren't taking. I Restarted the laptop in safe mode and now I can't get it turned off. I have accessed the pre-start up menu to disable the safe mode several times, but it hasn't taken effect yet. Any suggestions?
    Top Expert:
  • ASUS Master
  • 30,503 Answers
That is windows for you. All you can do is wait until they are finished installing, bearing in mind each time you reboot it will find more until it is ready. When finished, load your programmes and hopefully it will work. Or buy a Mac.
Posted on Jul 16, 2017
SOURCE:
  • 46 Answers
SOURCE: Restarted computer and it will not start
If you have a recovery cd, use that. Set your bios to boot from cd.
Sounds like the hard drive has crashed and you may have to reformat it and reinstall the OS...or change it.
Posted on Aug 14, 2009
  • 330 Answers
SOURCE: i tried to start my netbook in safe mode but the
for this problem you have to reinstall the os ..............
Posted on Dec 17, 2009
  • 20 Answers
SOURCE: After the set upwas performed on the pc,
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
hoyagese77
Posted on Jan 03, 2010
SOURCE: When Windows XP tries to load, I get the following
Enter in "Last known good configuration. Then Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" . Then right click on my computer icon click on property then click on hardware tab then click on "hardware profile tab" Then select another profile is there is 2 profiles then apply and check but if there is only 1 profile then you need to create new profile with below method. Click Start, click Control Panel, click Performance and Maintenance, and then click System. On the Hardware tab, click Hardware Profiles. In the Available hardware profiles box, click Docked Profile or Undocked Profile, and then click Copy. Type a name for the new hardware profile, and then click OK. Click the new profile, click Properties, select the This is a portable computer check box, and then select the best description for the profile (the docking state for the profile). Click Always include this profile when Windows starts.
Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 29, 2010
Joed911
  • 4338 Answers
SOURCE: new asus laptop. sitting idle this evening an
Go into Safe Mode and uninstall AVG. It may have been a bad update. Then re-install AVG or use Comodo, which is also free.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 02, 2010
My Yahoo Messenger hangs then it would say (not responding...). What can i do to fix this? Help me please?
Few sugesstions :
1) Check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to:
--> Control panel/ System & security/ Windows Update/ Change setting. In the setting panel, you will see " Important Updates " box selection. Change it to "Check for updates but let me choose whether to download & install them". Restart your pc/laptop, then try log in to your YM.
2) *This step won't be necessary but won't do any harm too, go to:
Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", Insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
3) If those won't work, uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
** If it still crash, then your internet connection might be the problem, & also, Yahoo! can be down sometimes too.
Jun 08, 2011 | Yahoo Messenger
I coudnt sign in the yahoo messenger,while i can sign in yahoomail.what could be the possiblem problem?could you suggest solutions
Few sugesstions :
1) Uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
2) If it does not work, check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to: --> Control panel/ System & security/ Windows Update/ Change setting
3) *This step won't be necessary but won't do any harm too, go to Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
May 27, 2011 | Yahoo Messenger
My laptop comes on and all I can get is the Vista screen and the message 'installing 3 of 3 updates 0% complete. Please don't shutdown your computer'. I can't get a menu or anything. What can I do to get...
Your computer has downloaded and installed a few updates. You need to allow the laptop to complete this sequence of events. Once completed your computer will boot just like normal. If you do shutdown the computer before the installation is complete you may have to download and install the same updates again. This is perfectly normal...do not take your computer to a repair shop!
Nov 18, 2009 | Dell Inspiron 1525 Laptop
What steps to take after installing a hard drive on a toshiba 350
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Nov 26, 2008 | Toshiba e-Studio 350 Copier
I can't setup windows xp sp2 in my laptop
why bother, go on the net and search for windows updates. dont use windows but another 3rd party site, they have all the updates to do this. i run my system on the earliest xp windows. i have to load sp1, sp2 and sp3, do you think i am going to wait 3 hours to download all the updates. 5 hours it took with the damn thing keep on switching on and off. now i load 1, 2 and 3, an hour and its all done. then just update for the extras which is malicious software update and a few security updates.
Oct 28, 2008 | Compaq Presario Notebook
Problem with the drive
Hi pravin,
One must pay close attention to the display screen when performing a new instillation of windows. Windows will show you the drive partitions. In your case windows will show there are two partitions. One C:\ & a second partition F:\. Perform a 3rd installation of windows. When you get to the screen where you can see both partitions (C: & F:) have windows delete the F: partition. Than have windows format the C: partition. Once C: has been formatted have windows install its self onto C:\
Install your driver software for your board. Than update windows through windows update service.
If you wish to back up your personal data to a CD/DVD writer, suggest you do this before formatting the system. Suggested folders to back-up.
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Once windows has been updated & you install anti-virus software you can copy & past each folder over the new folder in windows.
How to install windows XP. http://support.microsoft.com/kb/316941
Good luck pravin!
Mike
Sep 23, 2008 | Microsoft Windows Xp Home Edition Sp2...
P6860fx Performance Issue
1st of all you can not expoect great gaming perfomance in Notebook.
even the notebooks having NVEDIA Gforce 8400, 256 MB was not even comparable to my old desktop having NVEDIA 6200, 256 mb in a AMD Sempron 1.8 Ghz, 512 RAM desktop PC.
If you are a hardcore gamer, go for PS3 or XBOX 360, or may opt for a Desktop with good graphics.
And yes,there are NO alternatives to 3dmark. Plus to get good performance, look at the HEAT level of the Notebook.
Laptops freeze maximum time due to processor heating.
If your Notebook freezes due to heat in Less than 3 hour, its time you contact for a replacement.
May 25, 2008 | Acer Aspire 3680 Laptop
ASUS UX50VRMSX05 Notebook Logo
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
