Question about Dell Studio 15 Laptop
How to get eject the dvd disc from cd rom dell studio 1435
  • 3,940 Answers
Open MY computer, right click, select Eject
Posted on Oct 24, 2010
5 Suggested Answers
SOURCE:
  • 28 Answers
SOURCE: ejecting cd dell studio 17
Supposing that the Studio 15 / 17 has a slot loading drive:
You can either press the eject button above the keyboard (the touch sensitive one)
or
Go to 'Computer' in Vista and right click the CD/DVD drive. Then click 'Eject'.
This should work.
Posted on Jun 06, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Can't insert CD into Dell Studio 17 - ejects!
There are small plastic drive gears that respond to the drivebelt. These gears are very fragile and may have come out of syncronization.
Posted on Aug 31, 2009
Testimonial: "Responded in seconds with useful info."
venexcsd
  • 1185 Answers
SOURCE: Can't eject CD from Dell Studio 15
If you look at the front of the CD drawer you will see a little hole which will take a strong paper clip when it is straightened out.
Push the paper clip into that hole press firmly and the drawer will release so that you can get your disc out
Posted on Jan 28, 2010
SOURCE: Dell studio 1537 DVD drive problem
directions for replacing dell studio 15 dvd drive
Posted on Jan 30, 2010
My 1977098v-d6 will not eject
Possiblky the disc has moved even though on a spindle. When you say it will not eject is this using the software asking it to eject if so it will send the instruction to eject but when it finds a problem with the disc the tray will not open. So, get a pin or needle, in the front ogfthe drive will be a tiny hole behind which is the manual release. Stick the needle in the hole and push the manual release the tray should then unclick and you should be able to remove the disc.
Feb 29, 2012 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
My dell studio 1435 laptop is not opening its cd drive, i cannot insert cd/dvd on it. thanks!
Hello. Find a paper clip. Bend it open so it is flat and straight. On your CD Drive you will see a little hole that can fit the paper clip. Fit the paperclip in the hole and push. This will manually eject your CDRom Drive. Thanks for using FixYa!
Jul 11, 2011 | Computers & Internet
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
How do I eject a cd from a dell studio laptop?
Normally the studio laptops have soft eject for the CD and they dont have a button.. Press and hold the Fn key and then press the F10 key to eject the cd.. Another way is get into computer.. Right click on the DVD/cd rom drive and click on eject... This will work....
Sep 21, 2010 | Dell Studio 15 Laptop
Where is the CD drive on the Dell studio laptop need to put in disc for printer
you can see a slot on the right side of the laptop. you need to put cd in to that. you cannot see any CD Drive coming out of this model. Its a slot CD/DVD reader. So jst push the CD in to the slot. it will start palying. to eject go to my computer and right click on CD driver and click on eject. thats it ok
Jan 19, 2010 | Dell Studio 15 Laptop
How am i going to eject the disc manually?
Hello there:
This sounds like to me that your cd rom device is going out on you when the disk gets stuck and refuses to come out what you can do is to get a paper clip and sraightren it out now look on the cd rom door and you will see a verry small hole if you press in on the door button and insert the paper clip in the hole when you see the light for the cd rom door turn on press in on the paper clip failrl hard and it will release the locking mechanism and the door will open for you.
you can try to clean the entire tray and the slides tht the tray runs on get some canned air and spray the area really well on both sides and see if this helps
If not that you may want to consider havaing the cd rom drive replaced ok
Hope this is very help ful for you
Best regards Michael
Jan 16, 2010 | Dell Studio 15 Laptop
I inserted a disc (dvd) it will not eject. any
If the disk will not eject but however you got full power to the dvd rom then the dvd rom will need to be removed from the laptop and then opened up to manaul eject the disk.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 30, 2009 | Dell Studio 15 Laptop
Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Jun 28, 2009 | Dell Studio 1537 Laptop
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
Cd/dvd-rom wont run disks
Try using a disc cleaner ..
Mar 22, 2009 | Dell Studio 1737 Laptop
Dell Studio 15 Laptop Logo
274 people viewed this question
Ekse
Clive
Clive
