Question about Casio FX-9860G Graphic Calculator
I want to put an angle into degrees and minutes what do i press on the graphics calculator
  • Casio Master
  • 8,081 Answers
Here it is
To access the DMS symbols
  1. Turn calculator ON
  2. If you see no icon menus, press the [MENU] key.
  3. Use the arrows to put focus on RUN icon or RUN/MAT for the newer versions, and press [EXE]
  4. Press the [OPTN] key to display tabs in the lower part of the screen.
  5. Use the F6 key to cycle through all the tabs.
  6. Locate the one marked [ANGL] and press the key below it (may be F5).i want to put an - moz-screenshot.png
Here are two screen captures to show you the contents of screen
Posted on Oct 30, 2010
SOURCE:
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
How to put a calculator fx-9750GII in degrees
  1. Turn calculator ON.
  2. If you see no icons, press Menu then 1 to go to main calculator screen Run>Mat.
  3. In Run>Mat screen press SHIFT MODE to enter SetUp.
  4. Move the highlight to the line ANGLE. Press the F1 tab at the lower left of screen to select Degree.
  5. Press EXE to exit the SetUp screen.
Jun 17, 2012 | Casio FX9750GII Graphic Calculator
I need to be able to go from degree, minute, seconds (angle measurement) to a decimal number. I can't figure out how to get degrees, minutes, and seconds on the calculator.
  6. Locate the one marked [ANGL] and press the key below it (may be F5).moz-screenshot.png
Dec 19, 2010 | Casio FX-9860G Graphic Calculator
How do you put this calculator in degree mode?
Open the [Run] application screen.
Press [SHIFT][MODE] to enter (SetUp)
Use down arrow key repeatedly un til you see the line Angle:
Press the F1 key to select Degree as angle unit.
Dec 06, 2010 | Casio FX9750GII Graphic Calculator
How can I find sin 45degrees 20 minutes using a fx-9750G PLUS calculator?
The problem is not finding the sine of the angle but expressing the angle in Degree Minutes Seconds instead of decimal degrees.
  1. In RUN screen press [SIN] function key
  2. Press [OPTN]
  3. Press [F6] to get to next page of menus.
  4. Press [F5:Angl]
  5. Enter 45 and press [F4: degree ' "]
  6. Enter 20 and press [F4: degree ' "]
  7. If you have seconds to enter, type in value and press [F4:degree ' "]
  8. Press [EXE] to get your result.
This procedure will give you the sine regardless of the angle unit the calculator is configured for.
Sep 30, 2010 | Casio FX-9750GPlus Calculator
How do you put degrees, minutes and seconds (coordinates) into the calculator?
Jul 31, 2010 | Casio FX-9860G Graphic Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
TI-84 Incorrect sin/cos/tan values
What is so surprising? The sine and cosine functions have ranges that span the closed interval [-1,1]. As to the tangent function, its range is the the whole real line.
This being said, you should keep in mind that there are three angle units: the degree, the radian, and the grad.
When you want to calculate the sine, cosine, or tangent of a number, that number is not just a number. It is an angle, and as an angle it has a unit.
For this reason a calculator generally has two angle units defined (degree and radian), and possibly the grad. BEFORE calculating any trigonometric function you must ascertain that the angle is in the correct unit.
Clearly, in the problem you are trying to solve angle values are given in degrees, but your calculator is configured to interpret angles values in radians.
To set the default angle unit to degree press [MODE] , then press down arrow twice to reach the line (radian, degree). Highlight the word degree and press [ENTER] to set the default angle unit to degree.
Unfortunately the TI 8xPLUS family of calculators does not have a status bar on screen to remind you of the modes, and if you do not remember to check the current unit you get errors (at least unexpected results).
However, there is a way to avoid the errors and that is to enter the unit explicitly after the angle value. To do that you press [2nd][APPS] to open the (ANGLE) menu list. Try it.
  1. First item in list is the degree symbol, a raised 0
  2. 2nd is the minute, an apostrophe
  3. 3rd is radian, a raised r
By selecting the degree symbol and pressing [ENTER}, that symbol echoes on the screen just after the angle value. Closing the right parenthesis of the trigonometric function and pressing [ENTER] will give you the result in the correct unit of your choice. This can be done regardless of the default unit the calculator is configured for.
Jan 21, 2010 | Texas Instruments TI-84 Plus Silver...
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
Minutes
Yes. Use the following procedure to enter an angle in degrees-minutes-seconds form:
Enter the number of degrees. Press "2ND" "ANGLE" "1"
Enter the number of minutes. Press "2ND" "ANGLE" "2"
Enter the number of minutes. Press "ALPHA" " (double-quote above the +)
The ANGLE key is the APPS key.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Casio FX-9860G Graphic Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
