Question about Sony Playstation 3 (PS3) Console
Re white and yellow cords
Hey, my cords for my ps3 arnt working .... just last night i hooked it to my friends HD t.v and change it to HD settings now nothing shows up... it turns on in all but wtf plz help ..thanks
  • 27 Answers
Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode so that it can be viewed via rca/scart connection.
Posted on Jun 09, 2008
I had my ps3 hooked up to the plasma with a hdmi cord, my tv went out n i had the setting of the ps3 to hdmi, now idk how to change it to where i can hook it up with the original cord(red yellow white).....
To go from HD to composite you have to do while in HD mode do to the fact that the PS3 will only automatically detect HD and not composite. You can try doing the composit hook-up and then start in SAFE MODE.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Tip
Chances are ur trying to use a HD tv but u have the settings wrong on ur ps3. so...
Hi there
The no display problem is very annoying as you check all your cables and everything is fine but still nothing shows up on the screen,
What is the no display error
Again this problem is pretty much what it say's, you know you have this when you have no display on the tv when the PS3 is all set up correctly
The Causes
The basic causes are cables not connected correctly or you have a cable that is not compatible with your Tv/PS3
It can also be PS3 settings that are not correct.
The bigger problem is the Display chip internally or hardware failure.
The Solutions
Solution 1
Ok so you can send the console off to sony they will collect it, repair it and send it back, this will usually cost you $150
Solution 2
My favourite solution is the PS3 repair guide, you can fix the problem within the hour, costs are below $40 and you don't need to be technical at all.
Solution 3
Buy a new PS3 console over $200 this is the last resort.
What is PS3 repair guide
Ok so this is how i learned so much about PS3 and got me into the job today of fixing PS3's
The basic PS3 repair guide: is a high quality Pictured ebook, with the most basic step by step instructions that will fix your PS3
A good PS3 repair guide: This will contain the above mentioned and will also have a website which you can get 24/7 tech suppot to help with the fix, A forum with over 60,000 user's who have been in you position and can help you. Also some have great step by step video's.
The PS3 repair guide Comparison site
Ok i want to introduce the PS3 Problems gone Website this will be pivital in helping you choose the best repair guide, to get the best head start in fixing your PS3 you need to see the best repair guides on the Web today.
Conclusion
Ok so get your ps3 fixed get back to gaming and if anything else happens to fail you have your back up with the PS3 repair guide as its your's for life.
Good luck and happy gaming
on Jul 08, 2010 | Sony Playstation 3 (PS3) Console
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
When I put on my ps3 my tv comes up not supported
when you go to turn it on, press and hold the power button until you hear a 2nd beep, then let go. that will set the graphics card back to regular not HD, plug the ps3 in with the yellow red and white rca cord. and you should see the ps3, then once you have your ps3 working you can switch the cord to the HD cord and use the ps3 to see what signal your tv can use by going to Settings>Display Settings>Video Output settings on your ps3 xmb. hope this helps
Dec 03, 2010 | Sony Playstation 3 (PS3) Console
Hey guys i gave my ps3 to a shop in st neots to get my hd working and he blew out all the dust with a air gun and changed the settings and said the ps3 is set up for hd now and it worked on the shop tv but...
When changing the display mode of the PS3 you must be in the correct mode and be using the correct wire. If in the shop it was last set up in HD mode, then you must be using an HD cable (component cable(wire with red/yellow/white) will not work. Also, make sure that your TV can handle the resolution it is set in. If your TV at best handles 720p and the PS3 is set in 1080, then you will have to hook it up to a TV with 1080 to change it back or you will not get a picture.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Problem with audio & pic
Have u ever plugged in the HD cable or fiddled with the output settings...?
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
