Question about Bosch Nexxt WTMC 3300 Electric Dryer
Dryer start/pause button flying and lint filter. Dryer won't run.
  • Bosch Master
  • 2,605 Answers
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch.
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason. This will require you to remove the back panel though.
Once you've remove the rear panel, It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
Dryer start/pause button flying and lint filter. - e7dd751.jpg
If you`ve already taken the back of the dryer off before to gain access you should have no problem. If you never have, it`ll take some time.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
i.e.
Keep me posted how you make out or if anything is not clear.
Check out my page, It is still a work in progress, but you should find what I do have helpful for you're machine...here's the link.
http://cid-674627ce75316bb3.office.live.com/self.aspx/Bosch%20Stuff/tub.wmv
Please respect the guidelines of FixYa and my privacy, if you have any further questions or require more assistance, post back here not on my "live" page.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Oct 24, 2010
SOURCE:
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
Dryer won't start, replaced start button
The push-to-start button is not, in most cases, the culprit. There is a thermal fuse on the blower housing and wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Feb 10, 2011 | Kenmore Dryers
Dryer makes click when push start button but wont start
The problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Feb 01, 2011 | Kenmore Dryers
My dryer won't turn on it works great but suddenly I can't turn it on. When I push the button to start there is nothing.
The dryer functions are all impaired if the motor doesn't run. The heating circuit is activated only when the motor runs because power to the heating element is routed through the motor centrifugal switch. The problem here is likely a blown thermal fuse because power to the motor is routed to it. The motor cannot therefore run if the thermal fuse is blown.
Dec 18, 2010 | Whirlpool WED5200T Electric Dryer
Lint filter light goes on; vent unattached so no blockage and lint screen is clean. Thermostat? Temperature regulator? Model 3510 - about 6 plus years old
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes, I mean if you have not done this already. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the Thermal fuse that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 15, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My check lint filter light is on, lint filter has been cleaned. is the exhaust line possible clogged? I have a Epix Z series dryer, the lint filter was not cleaned and now the check lint fileter light is...
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2010 | Maytag EPICz 6.7 Cu. Ft. King-Size...
My dryer's check lint screen light will not go off. I have cleaned the screen and vacuumed out the lint trap and it still will not reset.
Hi
Thanks
Rylee
Jul 28, 2010 | Kitchen Ranges
DPGT650EHMG CLEAN LINT FILTER LIGHT WILL NOT GO OFF
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | GE Profile DPSB620ECWW Electric Dryer
CHECK FILTER
Hi
Thanks
Rylee
Jun 06, 2010 | LG DLE5955 Dryer
My kenmore dryer keeps shutting off mid cycle.
sounds like your motor is over heating and shutting off.once it is cooled it starts.listen next time and see if their is a humm or pause when restarting the dryer.solution is replace motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
224 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
