Question about HP Photosmart C7280 Printer
I am getting white block on my prints(no color) when a print photos on a HPC7280. Using Windows 7.
    Novelist:
  • 119 Answers
Check if you are using Windows Photogallery to print or some other application... If not windows photogallery then right click on any of your picture, click on properties Click on 'Change' next to open with select windows photogallery from the list Click apply then Ok
Open the photo after that, click on print and on the window which opens up, click on the Options which is at right hand bottom corner A pop up windows would open up, click on printer properties and select the quality from Automatic to best Select the size of paper that you are using Then go to the advanced tab on the same window at the top and check the box which say maximum DPI Then try to print
Posted on Oct 24, 2010
SOURCE:
My hp printer casts purple to black and white prints
Tried your settings with no luck. Also tried every canon profile listed to no avail.
These are my settings:
Color management:
Color handling: Photoshop manages colors
Source space: sRGB...2.1
Printer profile: Canon MP620 Series GL2/52G
Rendering: Perpectual
Media Type: Glossy Photo paper
Print quality: standard
Effects: borderless
Printer Preferences:
Color Intensity: manual-set-everything is 0-matching:none
I am using Kodak glossy paper and I am using that setting. I am printing a digital scrapbook page with color. I used black and white pictures in the page trying to get rid of the purple trees, so it shouldn't be printing any color at all in the photos, but the limbs are still purple.
Under color settings in PSE I have checked "optimize for printing".
I am off to the store to pick up another package of photo paper..maybe HP or Epson will be better (I think those are the other 2 choices in the store)
Will check back in after I try the other papers
Aftermarket car headlights
Jun 11, 2012 | Office Equipment & Supplies
My project does not print with the correct color - even using the "best" setting. I have a gold background and it's printing with a blue/gray background. The photos are in color, but the...
Double check that none of your printer's jets is blocked (test page!) and convince Print Shop and your printer's settings that your process colors are the ones in the printer, e.g. RGB or CMYK versus CKMY, 7-color, etc.
Sep 30, 2011 | Broderbund Print Shop® 21 Pro Publisher...
I have a pixma 1500 and I need to print black and white prints. I am using edible paper and edible ink. Instead of black and white I am getting pinkish gray instead of gray. I was told before that I...
Apparently, when grayscale printing is selected, some color ink is still used which is why you are getting a pinkish gray color instead of just gray. Here are instructions for solely using the black ink tank.
Print using pigment black ink only (Windows)
Instructions to print using only the pigment black ink tank only. Occasionally you may need to print using black ink only. Using grayscale alone does not provide this option and the color inks will still be used. By following this procedure you may print using only the pigment black ink tank.
Note: Some color ink will still be used for print head maintenance.
Note: Image quality may be sacrificed when printing photographs.
Open the Properties / Preferences window for the printer.
For Windows 7
Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
For Windows Vista
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/ Me/98 (if applicable)
Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
Click on the Main tab.
Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
Apr 23, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
In my Paint Shop Pro 7 program, my photos show in color. However, when I go to print preview, they are shown in grayscale. If I print them on either of my two printers, they come out in grayscale. I do...
its possible that in your printing preferences you have black and white selected. you can also try reinstalling the drivers for your printers, first uninstall them and then install the drivers again preferably newest drivers from the makers website.
Oct 20, 2008 | Computers & Internet
Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Aug 15, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
HP Photosmart C7280 Printer Logo
59 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
