Question about Maytag MGR6775 Stainless Steel Kitchen Range
Oven is often anywhere from 25 to 100 degrees off (cooler than indicated on panel). I Tried to use the "Adjusting the Oven Temperature" proceudre on page 11 of the included manual, but when I follow step 3, and press and hold the BAKE button, NOTHING HAPPENS. The oven does not go into "Adj" mode. I have read other questions elsewhere of people with this problem, with no answers. My thermometer only goes up to 400 so I can't calibrate higher than that. But that's not the real problem. The real problem is that the temperature adjust function does not work as documented in the manual.
2 Suggested Answers
SOURCE:
  • 257 Answers
SOURCE: The top oven of my
Read this........http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
Posted on May 10, 2011
HOW TO CALIBRATE OVEN TEMPERATURE INDICATOR AND THE OVEN TEMPERATURE ON THERMADOR PRD304EG RANGE
If you remove the knob, you will see the very center of the male part the know attaches to has a small flat head screw in the middle of it. Buy turning this screw in and out, you are micro adjusting the temp when the oven cycles on and off. Its best to have a digital thermometer set up within the oven so you can see exactly when the oven cycles on and off. It's going to fluctuate about 20-30 degrees. So set your oven to 350, let it turn on and watch carefully when the red light shuts off it should be between within 30 degrees from where you set it, up or down. If its too low,turn in( could be out, I forgot) the screw in the center of that know with a mini flat head screw driver. If you turn it and the light goes back on, you turned it up. If it does not go on in an quarter turn, you went lower. Once your digital thermometer matches up closely whith what your oven says, your good. 25 degrees isn't much to be gentile whith turning that middle screw, you could miss your mark and be off even more very easealy.
May 16, 2014 | Thermador PRD304EG 30in Pro Grand...
How Do I Calibrate An Old Maytag Oven
If the knob is consistently 25 degrees off from the indicated temperature the simplest and cheapest fix is to make a new indicator mark on the stove 25 degrees from the original.or some knobs have a glued on ring with the temperature numbers on them . Removing the ring and regluing it at the correct position could also work. Hope this helps.
Dec 31, 2013 | Ovens
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Temperature setting is wrong. Stove is about 80 deggrees cooler than what the knob is set at. I am a yooper too.
If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.html
Hope this will help you
Thank you
Oct 02, 2009 | Hotpoint RGB745 Gas Kitchen Range
Beer freezes
The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat.
Aug 17, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Oven temperature low
It sounds to me like you are using the convection oven. When you are using the convection oven it will heat 25 degrees lower due to the circulation in the oven. This is normal.
Feb 26, 2009 | LG LRE30755 Electric Kitchen Range
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Maytag MGR6775 Stainless Steel Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
