Question about Whirlpool Calypso GVW9959K Top Load Washer
Code SL or 5L? - Whirlpool Calypso GVW9959K Top Load Washer
    New Friend:
It is Code SL which means Suds Lock. Either you have too much soap suds for it to drain properly or Your drain pump is clogged and not spinning properly. Try running it through a rinse and spin cycle and if you still get a code (SL or Ld) then you will probably need to replace your drain pump.
Posted on Oct 25, 2010
  • mattinator Jun 03, 2011
    i kept getting SL code on Calypso otherwise known as Suds Lock and fixed it easily in under 10 mins. In my case, the pump and machine in general seemed to functioning so, i knew it wasn't the pump (i hate to admit it but i thought it was the pump and when i took the pump out, which took me 20 min's, it looked perfectly fine and yes, these machines are notorious for pump failures but that was not my issue). What happened was, some stuff got underneath dome/basket thingy (open lid, look inside washer, and you're staring at it - it's the round object in the bottom of the tub that moves the clothes up and down). It was, periodically, blocking the check ball valve or something like that and confusing the machine (the machine seemed to function, more or less, normally which was maddening). Remove dome using 2 flat balde, short screwdrivers. Insert into two of the four slots you'll find on the plastic dome thing. Push in, pry up - fairly hard. Ensure you use two slots side by side - do not use two slots across from each other (which, would seem more intuitive, i admit). At first i didn't think it was going to work but just keep at it - what you're doing is pushing in on a simple plastic clip so you need to push in, and pull up. Then use a socket to remove the 6 or 8 hex head screws holding down the basket. You can leave the screws in their holes. once they are all loose, pull it up, and you'll see the bottom of the stainless tub. therein you will, no doubt, find some stuff. I found: a 20 dollar bill (sweeeet), a plastic card, a quarter, and a large section of pillow case that my wife admitted had gotten stuck, and tore off a month ago by her hands (tks honey). ANyways, i was able to just hold the basket up with one hand, pull this stuff out one by one, and put the basket back in place without removing the loose screws and i had it back together in like, 1 min. It was really easy - easy enough for literally anyone to do (I am no repairman, though, i am pretty handy but seriously, my 10 yr old could have done it).
2 Suggested Answers
SOURCE:
  • 1531 Answers
SOURCE: we got error code SL or it may have been 5L...not
this is a long or slow drain issue you will need to check the drain pump for obstructions.
Posted on Feb 02, 2011
I have a dream maker spa has an error code of 5L or SL what is this
check recirculation pump then heater element then pressure switch
Dec 07, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
We got error code SL or it may have been 5L...not sure but it was after the Ld code..what does that mean?
Feb 02, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer keeps stoppng and it comes up with the code LD, OB, 5L i'm not sure how to fix it.
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
ERROR 5L WASHER MACHINE CALIPSO. THANKS
The error is SL.
SL = Suds Lock
Sep 15, 2010 | Washing Machines
Calypso displaying SL or5L messages, did you get it fixed?
I see at least 2 of these a week. 9 out of 10 times, it's the pump. If the u-joint is bad, it will put strain on the motor causing it to think it's overloaded as well.
Jul 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
SL or 5L error codes, Fixed?
Sorry, I haven't. In fact, I started to use my older washing machine, because I got someone to fix this one and it still wouldn't work. He told me that the newer models are not built to last, and that they are purposely built to break down and need constant fixing. Good luck.
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso 21086 top load
SL = Suds Lock
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Jan 20, 2008 | Kenmore Elite 21086
Whirlpool Calypso GVW9959K Top Load Washer Logo
150 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
