Question about Bryant Heating & Cooling
Blower motor my air conditioning goes off as soon as it goes on I have a service contract with my local oil company and my repair man said I need a Bryant blower motor 8539DL 51923EEOS I have been told the part is not available because the unit is to old and they recommend replacing my furnace and air conditoner for over $15,000 I am hoping I can buy the replacement motor somewhere so I can save for the future replacement of my units Is this part available anywhere?
  • goldynd Jun 09, 2008
    Where can I purchase this universal blower motor?
    Scholar:
  • 54 Answers
YES!! A universal replacement is readily available for around 200$ or so and the labor for the installation should be about the same. Sometimes it's hard to tell the Tech's and the Sales apart....GL!
Posted on Jun 09, 2008
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Tip
Save cost with some precautions
Precautions to be taken in air conditioners and to save cost.
These are some useful precautions to be taken in air conditioners (A/C).Improper refrigerant charge can damage your compressor, which is the heart of your air conditioning system; this is an expensive air conditioner repair. Systems improperly charged will cause increased electric bills because this will reduce the efficiency of your air conditioning system. The proper refrigerant charge will provide longer equipment life, lower your utility bills and reduce the need for air conditioning service.
A dirty condenser coil (outside unit) will reduce your air conditioning systems ability to remove and reject heat from your home. This will cause your system to run longer and increase your electric bills. The benefit of a clean condenser coil is proper heat rejection, reduced run time and lower energy bills. A dirty air conditioning condenser can lead to system failure and the need for you air conditioner to be repaired, dirt and house dust that escapes through your air conditioning filter can cling to the cold moist coil. This will restrict the air flow through the coil reducing your air conditioning system of performance and capacity. Maintaining the evaporator coil will ensure that proper air flow is delivered to all areas of your home, increase comfort levels, provide a cleaner healthier indoor environment. Inspecting and changing your air filter on a monthly basis will help prevent air conditioner repairs.
As your air conditioning system removes heat from your home, humidity is extracted from the air. The condensation created by warmer air passing over a cold coil must be drained from your system. This is done through a condensate drain line. The drain must be checked and cleared of algae build up or foreign particles clogging the drain, which could cause water damage to the ceiling or floors of your home. By keeping your air conditioner drain line clear you will reduce the need for air conditioning service and overflow problems which can result in water damage. Proper draining will also aid in maintaining indoor humidity levels.
Cause of air flow
Dirty blower wheels can affect the air flow to your home; limit your air conditioning system's capacity and your comfort. It can also spread dust particles which irritate sinus and allergies. A clean blower wheel and fan motor will provide maximum air flow, improved comfort levels and proper cooling. Most of air conditioner repairs are caused by dirt and the lack of maintenance.
Cause of electrical panel
Your thermostat should be properly calibrated. This will ensure accurate temperature control and operating cycle. This will save you on operating cost and assure your comfort level. Moving parts in need of lubrication can cause increased electrical consumption and air conditioner repairs. This is due to additional power required to overcome the resistance in motors and drive shafts that are not lubricated. Proper system lubrication will offer smooth motor and shaft operation, extended part life and less air conditioner repairs. The electrical components on your air conditioning system should be inspected regularly for signs of wear. Faulty electrical components can lead to very expensive air conditioning repairs. A thorough inspection will reduce the need for air conditioner service if the faulty or worn parts are replaced when found.
Carrying this tips help reduce the amount of air conditioner repairs you will encounter over your air conditioning systems lifespan. If you are in need of air conditioner service make sure the company you choose is licensed and insured to do the required repair work (warranty) .
on Feb 27, 2010 | Heating & Cooling
We have a 1990 Ford aerostar minivan and the blower motor isn't working. I don't know where the resistor is or where the blower motor is located. Anyone know?
Blower motor is in dashboard. Problem could be with motor windings, bearings, fuse, relay, and switch. Check them all out.
Nov 13, 2015 | Ford Cars & Trucks
Noisy pump when we run the dishwasher
Recently had a similar experience. Sounded like grinding noise for a period of time. Then motor stopped. Motor bearings were shot. Had motor replaced under P.S.E.&G. Service contract. This utility company offers appliance contracts for the home. P.S. serviceman indicated they will only do that once for the contract. This is an expensive part. If you don't have access to a contract be ready for 130.00 or more for a new Motor and more to have it installed if you are not handy. Service man removed front kick plate and dropped motor without removing dishwasher.
Apr 19, 2014 | Kenmore Dishwashers
Very loud "squealing" noise from fan blower for
Hello, if you cannot turn the fan by hand then the motor is shot. However, when power is applied to the motor and it starts after you give it a push then its the capacitor. Whenever you replace a motor tje capacitor must be replaced aswell because the microfarad rating of tne capacitor may have changed.
May 30, 2011 | Goodman CKL42AR42 Air Conditioner
A rattle and vibration coming frfom inside air conditioning vents
  1. Check the air conditioner fuse and replace as necessary.
  2. Air conditioner system discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  3. Air conditioner low pressure switch defective. Replace switch.
  4. Air conditioner fan resistor pack defective. Replace resistor pack.
  5. Loose connection, broken wiring or defective air conditioner relay in air conditioning electrical circuit. Repair wiring or replace relay as necessary.
Nov 23, 2010 | 2008 Volkswagen Jetta
The fan for my air conditioner will not turn. When we cut the system on it makes a humming sound and the light go dim for just a moment and this goes on repeatedly. No heat or air. We have a dual...
If the humming noise is coming from the attic it would indicate that the blower motor on the air handler is trying to start but the rotor is locked.
If the humming noise is coming from the outside unit and the fan runs but the compressor does not your compressor has a locked rotor.
If the blower motor is the problem the outside unit should still start as normal but you would have no cooling due to no air movement.
In ether case it sounds like you need to call a service tech to diagnose your system.
May 03, 2008 | Heating & Cooling
Condensor?
Hi, Sounds like the freon has leaked out of the unit and its time to call a repair company. The leak is probably the source of the oil. A service tech will find the leak, repair it if possible, recharge the unit and you will be cool again. Sounds like there is a lot of oil so the leak may be very obvious. Good luck. There is an ad on this site to find a local repair service company or you may want to ask a neighbor for a reputable company. kstfas
Aug 28, 2007 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
167 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
