Question about Panasonic Office Equipment & Supplies
Cannot get paper jam warning to stop, even after making sure that no paper scraps are anywhere in the machine. This is in a laser fax KX FL521 Panasonic. Tom Albertson, at dogs@cmc.net.
    Genius:
  • 3,422 Answers
First please do s hard reset by unpluging all the cords from the back of the printer for 20min and then plug it back.
Posted on Jun 07, 2008
  • Priya darshan Jun 07, 2008
    Please CLICK HERE for some troubleshooting steps mentioned from Panasonic
    Brigadier General:
  • 3,614 Answers
HI there,
Try to unplug for a moment the machine and then try to turn it on again..
let me know again here
  • Panasonic Master
  • 13,433 Answers
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
Up to two pages can be force fed through before the machine stops taking the pages and a paper jam error report is generated.
Inside the document feeder are two small levers near the middle of the paper path. One will be near the first roller to tell the machine that there's a sheet waiting to be pulled. The other will be an inch or two farther in, to tell it the paper has reached the scanner glass. If one of those levers is sticky, the machine will "think" it's feeding a very long continuous sheet. After a couple of feet or so, it reaches its programed limit and gives up to prevent tying up the phone line on an endless fax call when the document is jammed.
Open the feeder, find those levers, and make sure they move at the slightest touch. If one won't pop back up every time, it will give the symptoms you described. It may be as simple as a tiny scrap of paper wrapped over it, jamming it in its slot.
If the levers move freely, you may have a bad optical sensor underneath.
Oct 22, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL521 Fax Laser Copier, New Toner
This is usually an indication that the toner cartridge wasn't shaken from side to side to distribute the toner evenly.  If this was done, the cause is probably a dirty drum.  Remove the toner cartridge and clean the drum. Either of these two solutions should solve your problem.  Best of luck.
Greg
Jul 09, 2009 | Panasonic Office Equipment & Supplies
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother Intellifax 2820 JAMMED
just clean paper path and clean all roolers and specially paper pick up roller.by mian jee
Dec 15, 2008 | Brother IntelliFax-2820 Laser Fax
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jam
My KX-FT73CX Fax always Paper jam when turn the machine
Sep 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
70 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
