Question about Homelite Mighty Lite Lawn Trimmer
I have a 26 cc model UT21506 .When I push throtle to speed it, the engine stop. It was whithout use 2 years ago. I clean the carburator but it don´t work. I can´t take out the slow sprea, because i don´t know how take out it. Thanks
    President:
  • Homelite Master
  • 1,545 Answers
The fact that the the engine won't accelerate is most likely a carburetor problem. Being that is was out of use for 2 years, it quite possibly has gum/varnish built up in the fuel system. The sensitive internal parts of the carburetor are most liklely dried out and brittle. They need to be flexible and soft. At the minimum, you need to have a gasket and diaghragm kit installed in it or even a complete rebuild kit.
The only other thing to try is to try to adjust the L and H mixture screws on the carburetor. Many times this will cure a non-acceleration issue, the only problem being what I think you have stated. It is difficult to grasp these screws as they have been made this way on purpose to prevent tampering with the fuel mixture (per EPA emmission rules).
Small aluminum tubing (sold at hardware and home improvement stores) forced over the heads of the screws will turn them and so will the crimping end of a #22 wire connector (ring terminal or spade connector works).Regular needlenosed pliars can't reach them...even the smaller jeweler's kind. Special tools have been made to adjust these carbs and once you know their shape, sometimes you can purchase one on Ebay.
Posted on Oct 24, 2010
6ya staff
SOURCE:
Why Engine becomes unstable after I use A/C?
check rpm whithout the ac if its the wright rpm.
ac uses also rpm .so when its whithout allreddy stalling ,it will for sure ,when you turn on ac.
Jul 26, 2014 | Toyota Corolla Cars & Trucks
Engine surging
Drain the gas replace fuel filter then see if that helps if not clean the whole carburator should stop it.
Jul 29, 2017 | Tecumseh Lawn Boy Push Mowers Insight...
6.25 190 cc mower wont stay started
your running out the gas in the carb out you need to rebiuld the carburator probably dirt in the carb from bad gas
Jul 22, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Jul 01, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Carburation & emission control?
check for broken or disconnected vacuum hose/line
also check for the fast idle sped control valve for defect
Mar 18, 2010 | 1983 Honda Accord
What are the adjustments for the high and low mixture screws on the carbureator? the carbureator is from an echo 500vl chainsaw.
Echo thinks your actual model number is CS-550EVL. Page 14 lists the starting points for carburetor adjustment here:
http://www.echo-usa.com/pdf/documentation/CS550evle_010186.pdf
Additional manuals for you saw can be found here:
EchoUSA
http://www.echo-usa.com/documentation.asp
More choices can be found by typing CS in the model: window then clicking “Search”.
Once initialized this is the best procedure I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 13, 2010 | Garden
Its a 80 and i go to kick start it and it wont tart so i push start it and it starts but when i twist the gas it dies
sound like your carburator is dirty have you cleaned the carburator out! and you must check the point and spark plug if spark is weak you will get the same response on the throtle this is a classic bike it will have problems!
Aug 29, 2009 | 1975 kawasaki Z1B
I have a older areins snowblower with a tecumshen engine and the screw that holds the lever to the linkage oh the block came off hold do you readjust the governor with the trollte wipe opne should the...
whithout the engine running the gov should be trying to full throtle. when started this should tell the carb to supply or restrict fuel/air to compensate for load or the lack of. but to answer your question....yes the gov should be wide open, unrunning.
Apr 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Craftsman lawn mower can not run without pumping the red button
The fact you need to keep pushing the RED or "Primer" button says that your engine is running too lean ie. not getting enough gas.
You probably have a carburator problem due to the old gas gumming up the inside of the carb. The gum and dirt is clogging some of the internal passages of the carburator. It will need to removed from the engine and cleaned. The carburator is held to the engine by 2 bolts and is simple inside. Carefully clean the carb. with either carb. cleaner or laquer thinner or similar good solvant. Reinstall and you should be fine.
Also be sure to check your air filter and replace if dirty.
The red button is a "primer" that pumps extra gas into the engine. It is normally used only only for statrup so if need to use it while the engine's running, you're running too lean.
Dr of Motors
Mar 21, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
292 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
