Question about Brother FAX-575 Plain Paper Thermal
What does mnl on the screen mean? - Brother FAX-575 Plain Paper Thermal
    New Friend:
What does mnl mean on my fax machine.
Posted on Sep 19, 2012
2 Suggested Answers
SOURCE:
  • 81 Answers
SOURCE: unable to receive faxes
I believe it is set to manual reception, meaning that you have to push start to get a fax. You should be able to go into the setup manual and select automatic reception. In this case the fax will answer automatically. You can test this by calling your fax number from another phone and observe it's behavior.
Posted on Feb 29, 2008
WHAT DOES MNL MEAN
Hi there. MNL refers to manual fax receive. You must manually answer to receive the fax. I normally have it set to "auto" to receive automatically. Use mnl mode if you have fax set up on a normal voice telephone line and not a dedicated fax line.
Feb 18, 2015 | Brother FAX 565 New
I have several questions: Number 1 the initial minutes of my premio (corona) D4 2-litre engine raves at above the 1500 rev per minute but eventually returns to less than 1000 after some minutes;...
George,
1) Yes It is normal for corona Engines to have that high rev when the engine is still cold. It automatically adjusts to the Normal Rev/min when the engine gets warm so don't worry about that.
2) The Buttons are use when you are running on road. PWR means Power meaning that you lock the car in gear Five while sprinting. MNL stands for manual transmission.
3) Econ tries to show you that you are using a higher gear like say 5, therefore your fuel consumption is now being economized and thus low consumption. Actually, its always good if you drive your car with that light on coz it saves on your fuel. It get on automatically.
Don't forget to vote my solution if it was of help to you.
Dec 03, 2010 | Toyota RAV4 Cars & Trucks
Screen says "mnl"
MNL indicates the fax is set for manual reception, you have to press "start" to receive the fax. There should be a button on the control panel for reception mode, press the button until it says auto or fax or fax only. If you do not have the manual, you can go to brother-usa.com and look for downloads.
Jul 15, 2010 | Brother IntelliFax-2820 Laser Fax
Our brother fax-827S will not send or receive faxes
The MNL setting has no effect on sending. Try unplugging the power for 10 seconds to see if that clears the problem. Make sure you have a dial tone on the phone line.
Apr 15, 2009 | Office Equipment & Supplies
I have the code MNL on machine
HEY BOB!MNL MEANS THAT IT IS MANUAL MODE.  PLACE A PAGE IN THE MACHINE AND THERE IS A BUTTON THAT SAYS FAX OR MODE. YOU WANT TO BE IN AUTOMATIC OR FAX ONLY. GOOD LUCL
Feb 01, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
I have MNL on screen, fax machine will not do anything
Probablt MNL means manual receive. Therefore the machine will only receive if you lift the handset and press the start button.
May 01, 2008 | Brother IntelliFAX 2800 Laser Fax
Unable to receive faxes
Feb 29, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Cannot receive faxes...... display on the message panel sleep MNL
The machine is set for manual (MNL) answering - hit "receive mode" until is says "fax only" or "Fax/tel" etc. depending on what mode you want the machine to work in again.
Just resolved the same problem on mine.
Patricia
Jan 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother FAX-575 Plain Paper Thermal Logo
1,309 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
