Question about Sony VAIO VGN-CR220E/P Notebook
I have a sony laptop . it used to get switched off all of the sudden when i use it for more than 1 hour . so i took it to sony showroom and got it checked ,they told because of the over heating laptop is getting switched off . and the fan was replaced .but nw after replacing the fan also its getting switched off .so what can i do next
  • Sony Master
  • 4,924 Answers
The sudden turn off is a protection that it is supposed to do when the CPU gets to the max allowed temperature...if you changed the heat dispenser and the cooler..the next thing to do is to get an external cooler for laptops..its the only way that you may use it for long perods of time without problems ...The issue is probably the zone that you live on ...(probably a warm place ) ..and the way you use it ...cause they are made to not do that in normal conditions ..
Another thing to check is the settings in BIOS ..just get into the bios and select the factory optimal defaults ...and after that confirm choice and save the changes with F10 ...and enter to confirm and exit..
This will make sure that you do not have a lower level of temperature set as maximum allowed for the CPU..
This is a link for some kinda device I mentioned..(external cooler..)
http://www.tigerdirect.ca/applications/category/category_slc.asp?CatId=3486&name=Notebook%20Coolers
Posted on Oct 24, 2010
SOURCE:
IC PROBLEM IN SONY VAIO.PLEASE HELP.ITS TOTALLY DEAD NOW
Unplug, remove battery, clean fan and vents, plug in, reboot. post results.
Feb 07, 2013 | Sony VAIO Computers & Internet
Hello, I was working with my sony vgn-ns110e for 5 hours and all of the sudden the laptop shutdown. It does not turn on anymore and there's no light either in the power, batt or hd.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad
5. The motherboard could be defective & needs to be replaced
Sep 17, 2010 | Sony VAIO VGN-NS110E/W Notebook
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
Dell Inspiron. laptop wont start
see....there is nothing to afraid....as u said your laptop was booting and you pressed cancel ..thats why the windows information are lost......format your laptop again and load the window again.
Feb 16, 2010 | Microsoft Xbox 360 Console
Hello, please help.. I have a 14" Bluesky TV set(NR BK 36 GR)but my channels had vanished and when I push the menu button on the remote control I get only the image menu (contrast ecc..) and essential...
Try unplugging the set for about 8 hours,press and hold power button for 3 seconds, wait 1/2 hour more, plug back in and see if the tv has reset itself.
Nov 10, 2009 | Televison & Video
Sony Vaio PCG-6h4l laptop turns off for no reason. While using laptop on batteries it works fine and does not power off while using. But while using with electricity the laptop turns off for no reason,...
It could be that the laptop disables it's battery when you connect it with the power supply. When the power supply then fails it won't have enough time to switch back to battery. You'd best first try another power supply, and post back here if that doesn't help.
Jun 07, 2009 | Sony Computers & Internet
W810i not turning on
hi,
I think theres some problem with phone's board..so pls try to take your mobile and service it in any nearest sony ericsson showroom..thank you!!...
Jun 30, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Laptop just went blank...cannot power up or turn on
try by resiting the ram, if the problem persits than your display adapter is having problem
May 19, 2008 | HP Compaq Presario V2000 Notebook
Sony VAIO VGN-CR220E/P Notebook Logo
134 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
