SOURCE: I have a 6 burner
Dear Kathynearing,
Hi. I have experience cooking in a burner like that it keeps on burning coz the ignition coil was press by your switch knob coz the spring was stack up try to release it so that it will not be ignited all the time when your cooking. This should be ignited at once. If it gives light already it should be released. Please reply if you have solved the problem so that I can give you more advices.
SOURCE: No gas to the oven. Ignitor is lit. Top burners work properly.
I have the same problem. The burners work but not the oven. Ours started beeping with a FO code. The tech came out and said the control panel is bad and needs to be replaced. He also said ALOT of people are having the same problem and they might do some kind of recall down the road but for know we have to wait til Jan to get our part to fix it. Boo
SOURCE: My Thermador Range (Model #GCV36G)
A yellow flame that high indicates that the air input is low so the mixture is too rich, so it lights very hard and it gets a poor flame.
The defect is in the burner, it's clogged by dirt. Try to clean it from the outside just by pulling every loose parts. If that fails the top of the range will have to be removed to access the entire burner, take it out from it, dismantled and cleaned thoroughly.
You can find the necessary diagrams here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232125&diagram_id=193462#d193462
But i must warn you: you will be working on a gas unit; if you can't be sure you can do the job properly, without causing any leaks afterwards, you should call a repairman.
SOURCE: My 36" sealed gas cooktop
I had that problem also. It seemed to me that when anyone set the flame too high for the size of pan, the burner overheated. Then when the burner was turned off the igniter made clicking noises for a few hours...till it cooled down.
When I cooked at a lower setting all was ok.
This is free help...please take time to rate me....good luck.
Here
is a tip that I wrote that will help figure out why the burner spark
keeps on clicking...
Gas Range Repair Burners
Keep on Clicking
heatman101
